Snapping noise from front end
I see from your photobucket that you use yours pretty good too. I had a similar problem and did find the rear trackbar extension on a teraflex worked loose I blue locitited the bolts and still had a noise. thought it was from the front but after I pulled all the brakes and cleaned them up i found that the rear e brake was corroded to heck had to clean the heck out of the adjusters behind the Rotor-drum on the rear brakes. Mud is fun but it sure is hard on parts. Mud must of seeped into the e brake area and dried up.
Jeep should of calipered the e brake as well...
From: Hangin in the sunshine state....staging forum..
I'm mostly in the mud so not to much flexing to make it hit the tranny. I'm going to check all the bolts soon.
I hate those hard to track down sounds.
Mine did the same thing after wheeling a few weeks ago. I torqued the lower control arms and track bar, but also greased the heck out off them at the same time. Took care of it for me.
Ok not sure how I missed it but my front passenger side lower control arm is loose, well the jam nut is loose and the end isnt straight like on drivers side. I am hoping I can tighten the nut and straighten the arm without taking it off. I need to get a BIG crescent wrench though first.
This is the part I am talking about, its not straight on that chrome ball, its cocked to the side.
http://project-jk.com/wp-gallery2.php?g2_itemId=20884
