Sound bar rattle
Old Oct 26, 2012 | 06:51 AM
JK yeti's Avatar
Originally Posted by Hskr4x4
Don't waste your money going to a hobby store for poly fill. Go to walmart and get there $2.50 polyfill pillow (usually on end cap in pillow isle) cut pillow open and pull the fill out. You will only use at max a half pillow... Safe yourself some cash and do it that way
Got 2 big bags of poly fill for $2.00 from hobby lobby. Only took half of the first bag to fill the soundbar
Old Oct 26, 2012 | 07:55 AM
TJM12's Avatar
Not only did I take the grills off because my polks mm's where a little to high after mounting in the sound bar causing the grill to come in contact with the speaker but the real culprit in the soundbar is the lens on the light. It rattles and resonates pretty bad.
Old Oct 29, 2012 | 05:34 AM
BrowHeezy's Avatar
I put Alpine Type-X components in both the front dash and soundbar. With the crazy set-up I have, I was a able to turn off the bass in my components, no rattle at all...
Old Feb 7, 2013 | 12:40 PM
Bradschneider's Avatar
When stuffing the sound bar, did you put any pollyfill around the speaker itself? I stuffed the middle of the sound bar, but i left the area, directly in contact with the speaker empty. Can i stuff that area as well? I am worried about the pollyfill touching the speaker.
Old Jan 18, 2015 | 02:33 PM
jbied's Avatar
did the poly fill but still get rattles. Anyone try using speaker baffles with any luck?
