spacer install throws off alignment?
I installed 3/4" coil spacers in the front and didn't even have to re-center my steering wheel. No alignment problems. 3/4" doesn't change much.
You should give the JK owner who told you about the alignment problem the web address to this forum. Maybe he'll learn something.
Thanks for all of the comments and info. The spring spacers are going in this weekend, so I'll post how everything went, and any changes that I have to make.
JD
I put in 1 3/4 spacers this weekend and I think my steering wheel may be to the left, just a hair...or it might just be my imagination...
Did you get your spacers in?...did you need to recenter?
I installed 1 3/4'' spring spacers with the factory pad removed for a 1 1/2'' total. Then I installed 1 1/2'' wheel spacers which have caused ABSOLUTELY NO PROBLEMS OR TIRE WEAR WHATSOEVER IN OVER 20,000 miles. Do it......
I had to make no adjustments whatsoever....
JD
