spacer install throws off alignment?
Old Feb 26, 2009 | 03:40 PM
jd1066's Avatar
Originally Posted by nclehmann
I installed 3/4" coil spacers in the front and didn't even have to re-center my steering wheel. No alignment problems. 3/4" doesn't change much.
You should give the JK owner who told you about the alignment problem the web address to this forum. Maybe he'll learn something.
I have, but unfortunately, he is just not an internet person. He thinks computers are evil!
Thanks for all of the comments and info. The spring spacers are going in this weekend, so I'll post how everything went, and any changes that I have to make.
JD
Old Feb 28, 2009 | 07:42 PM
jmat1980's Avatar
I put in 1 3/4 spacers this weekend and I think my steering wheel may be to the left, just a hair...or it might just be my imagination...
Did you get your spacers in?...did you need to recenter?
Old Mar 1, 2009 | 04:07 AM
TINMAN080's Avatar
I installed 1 3/4'' spring spacers with the factory pad removed for a 1 1/2'' total. Then I installed 1 1/2'' wheel spacers which have caused ABSOLUTELY NO PROBLEMS OR TIRE WEAR WHATSOEVER IN OVER 20,000 miles. Do it...... I had to make no adjustments whatsoever....
Old Mar 1, 2009 | 08:32 PM
aldaman's Avatar
I installed the TeraFlex 1" front coil spacers with no issues and didnt have to recenter my steering wheel nor get an alignment...The Jeep drive great....
Old Mar 2, 2009 | 03:18 AM
Mark Doiron's Avatar
Originally Posted by jd1066
... Considering that I had an alignment done this morning ...
I know I'm a little late to this thread, but I'm curious why you felt that an alignment was necessary in the first place.
Old Mar 15, 2009 | 07:07 PM
jd1066's Avatar
Sorry Mark, I missed this one. I took it in for an alignment because I thought I had bent my pass side axle C, and wanted to have it checked out. I posted about it here, and someone (RedneckJeep - I think) said that the toe in could cause what I was seeing, and suggested that I have it checked out first. Thankfully he was right, the toe in was way off, and the C was fine.
JD
