Spare tire extension bracket...which one?
Trying to narrow it down.. I need to get a 33" on, which I know will work with the stock carrier, but I relocated my third bracklight to a custom setup inside the spare and I need the spare to remain in the same orientation, so same bolt pattern config as what the stock carrier requires. But I also want to be able to run with the rear window open a crack, so I want to move the spare out an inch or two...
The ORW bracket is the cheapest and raises the spare up as well as out. But they rate it only up to a 32", I need up to 33.
Rough Countries is an easy fit, not too expensive and is rated to a 35", though I think the rating concern is for the structuraly integrity of the JK's gate, not the bracket.
From what I can tell, Warrior makes a couple of versions... Not sure of the differences other than finish. This has the benefit of being able to mount in a few different orientations, but for my use, that is not needed..
Two questions...
What's the good and bad news about these options?
None of these will have the spare pressed against the rubber snubs on the rear gate...is this a problem?
Two questions...
Why not look at the Rough Country wheel spacers (like spidertrax only cheaper). They are 1.5" and are strong enough to mount the wheels to the axle so they are plenty strong enough to mount just the spare. Also you get 2 for $60 and you can sell the second one on the sales forum to someone else who wants to upgrade to recoup some of your costs.
So does it matter if the spare isn't pressed against the rubber snubs? I thought that might be spreading the load of the spare across the rear door instead of concentrating it only on the carrier.. don't want the carrier to rip out of the gate and don't really need a swing out carrier.
http://www.teraflex.biz/products/wra...n-bracket.html
$32.99
ooops not sure why it turned out so large.
Thanks anyway..
The extension is nearly 3"... far more than what I need. and... "If too large of a tire is used severe damage to the tailgate will occur. We do not recommend tires over 32” to be mounted on the factory tailgate tire bracket."
Last thing I need is a wheel and tire, with my tailgate attached, bouncing down the highway....
Thanks. Price is right, but two concerns...
Extension 2.75"
Offset Up (Rise) 1.75"
