Spare tire extension bracket...which one?
Old Aug 12, 2009 | 09:20 AM
MikekiM's Avatar
Originally Posted by TeraFlex
The factory tailgate is known to bend from even from the weight of a factory spare tire. Hence the warning.
Extension 2.75"
Offset Up (Rise) 1.75"
How real is this? I am running 33's on stock Sahara wheels... can't be that much heavier than stock, but the added 3" extension must torque the bracket at greater stress levels...
Old Aug 12, 2009 | 09:32 AM
mkjeep's Avatar
Might be able to shim the stock studs with washers enough to get your spare on , just put some longer studs . Or those cheapo wheel spacer shims.
Old Aug 12, 2009 | 09:35 AM
TeraFlex's Avatar
Sponsoring Manufacturer
If your spend alot of time on the trail bouncing up and down that could cause it to bend. If your spending most of the time on the street then that helps. But some have bent the tailgate after just one offroad trip.
Old Aug 12, 2009 | 10:25 AM
MikekiM's Avatar
Thanks, I know I am beating this to death, but what bends? The outer skin? Does it impact how the tailgate closes or is it just cosmetic?
Old Aug 12, 2009 | 10:44 AM
TeraFlex's Avatar
Not sure if it's the hinges or the metal around the hinges that bends. The tailgates are just too light weight.
Old Aug 12, 2009 | 10:58 AM
hohokom's Avatar
I had the same problem when I went from stock M/T's to 35's. I installed the Warrior bracket and it worked fine. I had to cut my stock third brake light in to two pieces and install an extension, but all went well.
It lifts it up about 1-1/2 to 2 inches.
Old Aug 12, 2009 | 11:23 AM
MikekiM's Avatar
I'll take my chances... I'll order tonight. Thanks!
I've already relocated the brake light to inside the spare, mounted on the carrier, and a little bit of additional height would be fine.
Old Aug 13, 2009 | 10:42 AM
MBRP Tech 1's Avatar
MBRP Representative
Don't know how I missed this thread, but in addition to our spare relocate bracket, we also make a tail gate reinforcement kit...The four brackets bolt to the inside of the tailgate and add extra strength for running larger tires. No cutting...No welding. Easy and affordable.
Here are some images:
Old Aug 13, 2009 | 11:49 AM
mkjeep's Avatar
Hey, that's pretty damn cool, I myself was trying to think of a way to do that. There goes another damn million dollar idea I had
Old Aug 13, 2009 | 01:40 PM
Curiosity's Avatar
Wonder how much those brackets help... do they just distribute the weight more evenly where the tailgate hinge attaches? Its hard for me to picture how it would work w/ just 4 strips of metal, any pics of them installed? Any additional support would be nice as I just put on a set of 33's.
