Spidertrax intallation.. Need some help.
Old Feb 12, 2011 | 02:08 PM
D_engel's Avatar
Originally Posted by Deere_Jeep
The back of the spacer is not flat (there is a groove) where it attaches to the factory lug. It looks like the clips would not come in contact with the spacer.
Im very curious if mine are coming in contact with my spacers. I checked them after 1000 miles and they are still torqued down and they look perfectly flush with the hub. Ill pull the spacers and remove the clips just to be on the safe side.
Old Feb 12, 2011 | 06:14 PM
Deere_Jeep's Avatar
Finished up... 4/5 lugs had clips on there. No damage to speak of after 500 miles.. Added lock tight and torqued to 90 ft. lbs.
Thanks for the help everyone..
Old Feb 13, 2011 | 04:59 PM
D_engel's Avatar
did you leave the clips on?
Old Feb 13, 2011 | 05:22 PM
Deere_Jeep's Avatar
No, tooke 'en off. Flathead to pry it , and need nose/cutters to remove.
Old Feb 13, 2011 | 05:29 PM
ssg381's Avatar
Glad to hear you removed them clips..
Old Feb 14, 2011 | 04:43 AM
MSUConrad's Avatar
To make the front rotors not spin while you torque the bolts, you can either use the 2x4 on the brake pedal trick or just stick a screw driver in the top of the rotor. The screwdriver will hit the caliper and not let it spin.
Old Feb 15, 2011 | 03:06 PM
Deere_Jeep's Avatar
Got the brakes to lock in fine.. rechecking torque later in the week..
Old Feb 17, 2011 | 03:06 AM
Deere_Jeep's Avatar
http://project-jk.com/jeep-jk-write-...ation-write-up
I seem to forget about these write ups. The only thing different from this and the instructions is the torque.. Instructions say 80-90, here it says 95 ft. lbs.
Hope this helps someone searching for info.
Old Feb 17, 2011 | 03:16 AM
JK-Ford's Avatar
Originally Posted by melliscj
Don't risk it. Just take off the clips.
If you do not remove the clips. There is a chance that you will not be able to get the spacer to fit flat against the hub. If this happens, the wheel and tire will have a slight wobble when rotating. This may not be visible to the eye. But will be reflected in tread wear.
Old Feb 17, 2011 | 06:20 PM
Deere_Jeep's Avatar
Checked Torque and everything was great, except I found a nail in one of my tires, luckily it does not appear to be leaking and I can get it fixed!
I'm really glad I double checked the shops work.. It's obvious I asked them to do way more than they could handle.. I mean come on guys the instructions were in the box.
Thanks for the help all. This site is great and I learn more and more each day!
