Spidertrax spacers...?
Old Feb 6, 2009 | 05:34 AM
In5ane's Avatar
Default Spidertrax spacers...?
I just bought a used set of spacers from a guy up north. They seem in good shape, but the studs have some surface rust...probably from the salt and stuff...is it still safe to use these? Anyone have the same issure?
Old Feb 6, 2009 | 05:37 AM
Robar's Avatar
If it's just some surface rust I would get a wire brush and clean it off. I would bet they are safe to use. Just follow the recommended install when installing them.
Old Feb 6, 2009 | 12:38 PM
km2jk's Avatar
Pretty much any studs that have open ended lugs will have some minor rust. I wouldnt worry about it. Just clean it up a bit and use closed end lugs (like stock).
Old Feb 6, 2009 | 04:31 PM
blockrockin's Avatar
hey i sold you the spacers , they are only about a month old.i only used them for a few weeks till my new wheels came. they are fine.. their has been alote of snow around here lately .. but i think they would rust alittle anyway. nothing to worry about .. thanks again
Old Feb 6, 2009 | 04:41 PM
nclehmann's Avatar
Aluminum rusts?
The spacers are made of extruded aluminum, which doesn't rust. What you are seeing is probably rust from the lugs. Moisture gets in the threads and creates a bit of surface rust in the steel lug nuts. I wouldn't worry about it.
You're good to go!
Old Feb 6, 2009 | 05:39 PM
Robar's Avatar
Originally Posted by nclehmann
Aluminum rusts?
You're good to go!
The spacer it self is aluminum, but the wheel studs are steel and I believe that is what he is referring to.
Old Feb 6, 2009 | 06:01 PM
nclehmann's Avatar
of course!
Probably the same though. The threads have the rust - but it's probably superficial.
