Springs loose when flexed question...
Originally Posted by Hskr4x4
Shock shouldn't be flex limiter. That's why they make straps and bump stops. As for the coils, I've never heard of anyone's being lose when flexing as well as my own, so I'm guessing you have the incorrect coils. Is the shop that did your lift reputable, are you sure they are even JK coils?
Nothing will help sag, and the more you add like bumpers and winch the more it'll sag. If I remember right, your exact lift is known to sag. Down the road you may wanna add spacer and or body lift.
4wheelparts is a great shop. I would take back to them and tell them about the flexing and loose springs and have them look into it. There shouldn't be any cost since they did install. If lift is new and they can't fix issue, I'd honestly ask for a different lift (no new install costs)
4wheelparts is a great shop. I would take back to them and tell them about the flexing and loose springs and have them look into it. There shouldn't be any cost since they did install and if lift is new, and they can't fix issue, I'd honestly ask for a different lift (no new install costs)
Limiting straps and bumps stops will do that (thats all you need)
I'd cut the stress in half and just go back to them and explain the issues. They will make right of it!
No problem man... I'd be worrying about it too... Be glad they did install, that way you don't have to spend hours working on things when they have all the tools and time to do it for you.. Don't let them scam you into paying for stuff expecially if it's something the may have overlooked
Actually, it depends. Sure having spring clips will prevent the springs from poping out but your axel shouldn't drop that far anyway. Once tension is off the spring you no longer have traction on that wheel anyway. Why let it drop any further.
I have a Rancho 4" lift kit. The Rancho shocks suppied with the kit are selected specifically for the kit. They are designed to be the limiting device for downward axel travel just as the bump-stops are there to limit upward travel. They both dampen and limit.
If you are running long travel shocks then it is more common to have your springs "loose." This is one reason why they sell spring retainers, if you are not running long travel shocks then the shocks will be the limiting factor when flexing. The spring retainers keep the spring attached axle side while it droops on the tower frame side. If you have retainers you can have about 5 more inches of flex or the length of the inner spring tower on the frame before the spring will come out. In any case limiting straps help to prevent the spring dropping below the spring tower frame side and from over extending your shocks.
