stainless steel torx
Old Sep 18, 2008 | 06:57 PM
hunterbug's Avatar
Default stainless steel torx
hello all,
i was wondering if anyone has found stainless steel torx bolts to replace the factory torx bolts
thanks in advance
hunterbug
Old Sep 18, 2008 | 09:09 PM
dyolfknip's Avatar
Originally Posted by hunterbug
hello all,
i was wondering if anyone has found stainless steel torx bolts to replace the factory bolts
thanks in advance
hunterbug
They are sold at the vague store just over there/////////
Replace which factory bolts, there is a couple on the JK???
Old Sep 19, 2008 | 03:20 AM
hunterbug's Avatar
Thats just great. my second post and im already getting my balls broken. I said TORX BOLTS !!! DUH ..........
Old Sep 19, 2008 | 03:41 AM
HappyCurmudgeon's Avatar
Eternal ***erator
There are several Torx bolts...
McMaster Carr (mcmaster.com), or possibly Graingers (grainger.com) should have them. Also, there is likely a local nut/bolt distributor for the local shops, they would be able to get them for you as well. Some hardware stores have some nice selections. Here there is a hardware/lumberyard called Guy's that has a ton of miscellaneous nuts/bolts of every makeup.
Old Sep 19, 2008 | 06:47 AM
2kTiM5's Avatar
I think he implied you need to be more specific which bolts are you trying to replace? IE door hinge?
Old Sep 19, 2008 | 06:55 AM
Eternal ***erator
That's how I took it as well.
Generally, we won't bust your nuts until you have a good solid post history...
like say...
10?
Old Sep 19, 2008 | 07:42 AM
dyolfknip's Avatar
LOL....Just off the top of my head I will rattle off the Torx I have used on the JK:
Hard top
Soft top
headlights
door hinges
windshield
mirrors? (I think)
I am going to assume the door hinges, for now because you still havent said which ones. Those ones are aluminum. And $20 US a PIECE. I know this for a fact as I seemed to have misplaced one doing this: https://www.jk-forum.com/forums/jk-write-ups-39/bedlined-door-hinges-55020/ and had to order one.
So if you want to replace them put your old ones on the forsale section and make a solid $100 off them
Other than that I dont know why you would want to replace any of them. Please explain as you have me wondering now.
Old Sep 19, 2008 | 10:38 AM
simon's Avatar
Fastenal carries them. There are over 1500 stores nationwide. I'm sure there is one near you.
www.Fastenal.com
Last edited by HappyCurmudgeon; Sep 19, 2008 at 10:42 AM. Reason: removed hyperlink
Old Sep 19, 2008 | 12:22 PM
hunterbug's Avatar
hey guys thanks,
i want to replace the torx on the hood and by the pillar. and i guess there are more i havent even thought of yet..
thanks again
Hunterbug
