Started my front end project
Old Jul 15, 2013 | 09:01 AM
sdr0303's Avatar
Default Started my front end project
I have a 2012 Rubicon and I've been meaning to strengthen the front end for a while now. I finally have some time and all of the parts together. I thought I would document the process and get feedback.
What I have planned:
- Axle sleeves - Nitro
- New ball joints - Synergy
- C gussets - Teraflex
- Axle Truss - Rockrawler
- New tie rod - Synergy
- Drag link flip and new drag link - Synergy
- New front driveshaft
- New differential covers front and rear - Solid
...and some odds and ends.
I started yesterday in my shop by putting the JK up on stands and getting the front axle torn down. I wanted to start with the sleeves since I needed to leave the axle on the Jeep in order to hammer the sleeves in. After they are in, I'll remove the axle completely to facilitate the other installs.
I went ahead and made my own Nitro sleeve driver from 6061 aluminum:
I started with a solid 6" plug and 3 hours of machining later, I had the perfect sleeve driver:
I took that and copied a tool I had seen on Youtube made of some simple square tube with a steel striker plate for the hammer:
ID:	478269Click image for larger version
The sleeves sat in my shop's freezer for a week so with a buddies help and about 10 minutes they went in perfectly:
Next up are the ball joints.
- S
Old Aug 27, 2013 | 12:22 PM
sdr0303's Avatar
Update on the build. I got sidetracked for a couple of weeks with work;
After I got the Nitro sleeves in, I removed the front axle (since I was going to adjust the caster anyways) and started to work on the Teraflex C-gussets:
ID:	492463Click image for larger version
Got everything welded in (taking my time):
ID:	492465Click image for larger version
Then I removed the factory trackbar bracket (PoS) to replace it with the Synergy one:
Steve
Old Aug 27, 2013 | 12:25 PM
Offroad_Elements's Avatar
Former Vendor
Looks great! Slow and steady wins the race.
Old Aug 27, 2013 | 12:28 PM
sdr0303's Avatar
Then I started on the Rockrawler Axle Truss:
ID:	492469Click image for larger version
ID:	492470Click image for larger version
Finished putting in the Synergy trackbar bracket and the driver's side swaybar mount to work with the newly relocated one on the bracket:
Installed Synergy Control Arm skids and cleaned and painted:
Steve
Old Aug 27, 2013 | 12:31 PM
sdr0303's Avatar
How it sits now; got my Solid cover installed:
Tonight I tackle the Synergy ball joints, putting it back in the vehicle, adjusting my arm, and reassembly of the knuckles, axles, etc..
Steve
Old Aug 27, 2013 | 03:21 PM
Gman*2007's Avatar
Nice weld job, can't wait to see the finish product
Old Aug 27, 2013 | 04:29 PM
v8zracer260z's Avatar
Veteran: Marine Corp
Nice job looks great!
Old Aug 27, 2013 | 04:49 PM
Jersey_Devil's Avatar
Nice job! I'm definitely subscribed!
Old Aug 27, 2013 | 05:06 PM
sdr0303's Avatar
Thanks everyone. I hope to have it wrapped up this week.
Steve
Old Aug 27, 2013 | 08:19 PM
5150cliff's Avatar
Nice machining job on that sleeve driver. Looks like it cost a bit though. I would have assumed that with the freezing of the sleeves, they should have pretty much slid in with little effort or at worst, with a block of wood and a medium hammer. How easy did they go in by the way?
