Steering Shake
il try to look for the ball joints and check whats going on. if they are bad i hope the dealer will replace them cuz he didnt want to replace my steering since i have a bb. so all i got to do is jack up a wheels and move it around? and if it does then i have bad ball joints?
You will be looking at the ball joints which are at the ends of the "C" that are at the ends of axle where it attaches behind your wheel to the rotor. This "C" is called the steering knuckle and the ball joints sit in them.
wer talking about kuwait my friend, no one is specialized in jeeps, il be better of doing it at home my self. thanks for the replies and i will be trying everything you guys told me and wel see how it works.
Jack up the wheel a little off the ground put a pry bar or shovel under the tire and have someone apply leverage to it while you sit and look and listen for play.
What do you mean the steering shakes? The steering wheel or the wheels themselves? I have been experiencing shakes/wiggles in my wheels when hitting bumps. Basically, the wheels always feel loose. Unfortunately for me, these shakes and wiggles have gotten worse and intensified into full on death wobble at certain speeds. I feel the wheel wiggle at any speed, over most all bumps and divets. Nobody can find a cause thus far.
UPDATE!!!!
I just torqued the track bar to 135ft and the steering shake is defrinetly alot less. its still there though. i lifted one tire and put a shovel under it and moved it around and the only part moving and its slightly moving is the metal rod that runs across thats connected with rubber. so is that bad? or normal? and what about the rest of the wiggle how to get rid of it? or it will go away with a steering stabilizer?
