Steering Stabilizer
Steering Stabilizer
Looking for a steering stabilizer, is SKYJACKER the only company that sells one? Can you really tell the diffrence when using one?????
-E
JK-Forum Founder
Are you experiencing steering issues with your Jeep? If not, I have a hard time believing that you'd even need a new steering stabilizer or that one would even make a real difference on your Jeep.
I believe Teraflex makes one as well. I was talking to a local shop and they 'highly reccomended' going this route with the lift. Could be BS but these are so cheap I would not think they would push for it that hard unless they saw some need.
If anyone has lifted at least 3" without one and then added, would like to hear input on any difference when added.
I installed one on mine with my tires but only cause I had to do something. My tires were riding in the ruts in the asphalt and it felt like I had no control over the Jeep. I scared myself a few times on the trip over to 4WD. I think it made a huge difference and if you look at the factory stabilizer I had to laugh cause it looks like a straw.
Thanks 04drblur, that was basicly the same response as the shop, they said it makes a huge difference and well worth it, best mod when lifting for not much cash. I have always had one on my past XJ's when I lifted them and did at time of lift so could not say a 'before, after' difference.
JK-Forum Founder
JK-Forum Founder
305/70/16. Roughly 12 inch wide. I only had the 3/4 spacer in the front at that time. Yes it helped alot. I since then have installed the 2" BB and did not use the track bar relocation bracket and it is almost back to stock handling wise. I am goin to instal the relocation bracket and the 3/4 spacer in addition to the budget boost and see what happens.
