Steering Stabilizer? Steering Squirrly
Respectfully disagree with this statement. Fundamentally, it may be exactly the problem the guy is experiencing - where the set-up is has pinion angle within specs at the expense of caster. The result is a "squirrly" jeep or, at worst, the infamous death wobble.
I'd recommend to run as close to factory caster specs as possible - even to the point of having to swap out the factory CV driveshaft.
As I said before, it is balancing these two evils that is at the root of this problem. I'd suggest an iterative approach by dialing back in some caster and driving it to see if steering improves without geeting vibrations/noises from the fornt driveshaft. If the front driveshaft starts exhibiting problems before I achieved the right steering, I'd ditch the stock driveshaft.
Front D30 are high pinion so pinion angle is not going to be a problem on a 4" lift. The drive shaft is also super long so that also makes pinion angle not a factor.
