steering stablizer
Old May 8, 2008 | 02:33 PM
derekls's Avatar
Default steering stablizer
Can someone post up pictures of there stock steering stabilizer and measure from how far it it goes to the bracket thing. I need to know how far out to put the factory steering stab to put it back in the stock location
I am having trouble with my superlift steering stab and I am considering putting the stock one back on to see if it solves the problem
Old May 8, 2008 | 04:52 PM
derekls's Avatar
OR pictures of your superlift steering stabilizer working with the FT tracks bars
Come on... no one?
Old May 8, 2008 | 05:26 PM
blkpearl's Avatar
measure full compressed stroke, and full extended stroke, turn wheels full one way, check measure against the mentioned, and same with other direction, once you tighten up the bolts, rechech and make sure you are not bottoming out the stabilizer at full turn or over extending, if looks like bottoming out then slide the brackt...etc..there may be other ways, the first one i blew out was becasue i had adjusted two short so it would bottom out and blew out seals..
other folks may have some good ideas to
Old May 8, 2008 | 05:29 PM
derekls's Avatar
per the superlift instructions they said to pull out the stabilizer 16 3/4 inches and bolt it up, I have not blew anything with the stabilizer but the bolt that holds the stab on there is making marks on my track bars
As far as what you just said, pictures pictures, Im not good at the whole 'working' on my jeep thing yet. I mean I could try what you just said but chances are I would do it wrong and mess something up.
EDIT: The main reason I was wanting to relocate it was because it is binding with my track bar. No issues other than that... I did look at it today and tried to cock it around to where it would not hit and it appears it is going to be stress ful on the stabilizer .......as in its not meant to be cocked with the way the install brackets are made and the way they are going. Again, pictures would mean 1000000 words here if you can turn it till its out of the way of the stabilizer.
Old May 8, 2008 | 05:34 PM
seer1's Avatar
That Superlift steering stabilizer is the biggest piece of $h!t! I painted mine red as I hate white parts, plus the paint'll show if anything's bangin' around. Sure enough there's red paint on my drag link and my trackbar. I have a similar setup as yours and it's time for that to go! It's just too fat. I'm going now to order a Woods relocation bracket and a Fox stabilizer. I was hoping to wait until David decided to carry Fox, but it's getting too close to trail season around here.
Old May 8, 2008 | 05:38 PM
ChewyGranola's Avatar
Come on... no one?
Just went out to get a pic for you. its not great.
Old May 8, 2008 | 05:47 PM
blkpearl's Avatar
i got ya, to prevent the shock body from binding, i removed and place the stablizer backwards so the shaft was going into the axle bracket, and the fat body was steering ubolt bracket, here is a old pic, i got but hopefully will explain what i did, yea sure can get beat up on the trail, so could the tierod,,it has been on that way since i replace the first one about 10k ago no problems or binding..you will have to swap your bushings, different size little round metal thinga ma bobs...
Old May 8, 2008 | 05:51 PM
blkpearl's Avatar
like that bracket, moves up and out of the way....how much was it? and were ya get it? my solution was easy enough but would like to get mine above tie rod..
Old May 8, 2008 | 05:54 PM
the axle mount one is from Woods. you can get it off his site www.4xfix.com
username: jeep
password: forum
The tie rod bracket came with the superlift stabilizer.
Old May 8, 2008 | 08:43 PM
derekls's Avatar
Thanks for all those pictures, said a ton.
On mine, its hooked up with the super lift hardware the problem on mine occurs at the tie rod bracket bolt
Its making contact with the track bar, is yours?
EDIT: Maybe If I get the woods bracket it will allow me to move it away more from the tie rod?
