steering stablizer
Old May 9, 2008 | 07:15 AM
  #21
ChewyGranola's Avatar
Originally Posted by RedneckJeep
The method I gave will work with ANY stabilizer, no matter the brand. A blind man could set it up using that method.
I'm just saying that he got it setup right according to superlift.
Old May 9, 2008 | 07:17 AM
  #22
RedneckJeep's Avatar
I understand. I like keepin it simple though. I mean, why take chances, right? I'm so good at screwin things up, the less I read a tape measure, the better off I am. LMAO
Old May 9, 2008 | 07:24 AM
  #23
The Woods relocation bracket that I have moves the tie rod bracket down about 3/4" from where it would be if the stabilizer was connected to the stock axle mount location.
The trackbar is further away at that location.
Old May 9, 2008 | 07:25 AM
  #24
are you using the superlift relocater?
Old May 9, 2008 | 07:26 AM
  #25
derekls's Avatar
Yes the piece where you had to make the hole bigger to make it work
i did all that
is that what you mean?
Old May 9, 2008 | 07:33 AM
  #26
i did all that
yeah.
The further you move the tie rod bracket to the driver side the more clearance you will have.
I see a couple of options.
flip the bracket around or try to move the tie rod bracket.
Old May 9, 2008 | 07:37 AM
  #27
with my setup it is 19" from the end of the tie rod to the first u-bolt.
Old May 9, 2008 | 07:42 AM
  #28
derekls's Avatar
just measured mine, its 19 inches to the first u bolt too
I got a question when you flex does the Stabilizer move up or the track bar move down causing the contact or is one or the other stationary
Im confused about it, and it appears yours doesn have any marks and its close to the same location as mine
Old May 9, 2008 | 07:49 AM
  #29
I have that bracket with the stock stabilizer. It's a dang nice piece, too.
Old May 9, 2008 | 08:01 AM
  #30
CrunchyOatmeal's Avatar
I am having the same issue. I also have the woods bracket on.
