Stock Rubi Rails caused.....
I think so. A "real" set of rock rails tied into the frame would have prevented it.
Originally Posted by FlameRedJK
I'm no physics nerd but, there's a big difference between several thousand pounds of JK coming down on 1/4" steel and a bullet...what can stop a small caliber, won't resist bending forces.
So I thought I would post up the results of removing the rock rails.
Looks like there are only 2 issues.
1) Dent and chipping paint in the middle of the passenger door from the picture I posted above. Not much of a dent but enough to where the paint cracked and is chipping at the joint. Suggestions? I am thinking of getting some touch up paint, breaking the chips off and filling the space with touch up paint. Then when putting skins on making sure that spots gets covered really well with RTV. Might reach out to my buddy who owns an auto body shop and see what technique he suggests for making sure this doesn't become an issue down the road.
2) The slight bulge in the panel at the lower door hinge. Tried to push this back but seems pretty stuck there. Thinking that skins would force this to go back straight.
I did work on fixing the rail. I have it 95% of the way fixed. Just need to get the tabs bent back the same way as the driver side rail. I will probably sell them very cheaply to someone if anyone is interested. They were much heavier than I expected them to be! I think my father had a good point that I was lucky to have broken the rock or it might have been worse!
Chris: I sent you a PM, my inbox is now empty again so you can try to reply again. Also, what is the best way to reach you? I want to get the skins and sliders on order but I have a couple questions. Thanks!
