Stupid rubbing thing
The sawzall will work great on the rock rails. However, the pinch seam might be a little more of a challenge. Depends how far back the blade goes and what is behind to hit.
I prefer a metal cutting wheel on my right-angle grinder, but that will have its own challenges because of the curves around the pinch seam.
Just mark everything good so you get straight cuts.
An old carpenter's saying I often ignore (and regret when I do): "Measure twice, cut once!"
I just finished chopping mine - woo hoo! Looks great. I did one good thing and two stupid things that are worth sharing:
Good thing: I put an 8" metal cutting blade on my good miter saw, and it made short work of the rails. Went through them like butter and left a perfect edge needing no cleanup. Plus it provides a groovy Fourth of July show during the cutting. :-)
Stupid thing #1: I marked the cuts with masking tape and left it on when doing the above cutting. It got so hot that it melted the tape into the existing paint, which left a grimy mess that had to be scraped off, including the existing paint.
Stupid thing #2: After slicing off the sheet metal with a metal cutting blade on my recip saw (again, super easy and went through it like butter), I plugged the gap with silicon like someone suggested. Do this AFTER you spray on your black primer. I did it first, leaving some silicon residue on the surface to be painted.
A n00b question - I have a Black & Decker sawzall thing; if I bought a metal-cutting blade would that suffice for both cutting jobs? Or is there a better tool I should buy, like a grinder thing?
