Superchips flashpaq gas mileage savings spreadsheet!
#31
re: superchips with stock vehicle
Is this worth getting if I'm still 100% stock?? I have an unlimited auto w/ 3.73 gears. Can I still get enhanced performance from this device being stock or should I just wait until I get my lift and 35's??
Should I wait until my factory warranty is up before installing the superchip or will this not cause issues at the dealership if I have any warranty work to be done in the future?
Look at the HUGE thread about superchips (search for "Initial Impressions" and you will find over 1,000 posts about it)
There are many using this with a stock setup that say it's fantastic.
My rational; if you have the $ to get it now instead of later, get it, and start saving on gas now. (and you'll love all the other benefits)
I run stock tires (rubicon mtr's) in winter and 37's in summer. This tool is PERFECT for this, as i can easily adjust speedo/optimize shift points through tuning for either scenario, and maximize mpg (and power for the big tires!)
Have a good one
#32
I asked a long time ago if anyone tracked their economy over time and got hardly a response with only one or two "spot checks" on long road trips and such - maybe now that it's been out for a while someone has tracked it over say 10-15 tankfulls (both factory and superchips tuned) and can give a better real average...
#33
I've always checked my mileage manually, and I can say mine has always been withing a couple of points of what my dash display says. I stay between 15 and 16 MPG at stock depending on how and where I drive. I was close to 17 most of the time before all the Ethanol crap.
I hope to get my Superchip today, and I'll continue to check manual and let you guys know.
#34
Superchips vs. Hypertech ECON
Not sure if this is the best thread, but has anyone been able to compare the mileage results with the superchips flashpaq versus the Hypertech Max Energy Econ? While performance gains are great, I'm really on interested in improving my mpg. Any information would be helpful, especially since I've dropped at least 1mpg since putting on my winch (really need to switch to synthetic -drop the weight).
#35
#36
#37
Ok. I am trusting you guys on this one. I just ordered the flashpaq from Northridge. My wife will be so proud of me.
Gas mileage improvement will be a plus but I am mainly looking for some performance increase as well as looking forward to getting my speedo calibrated correctly since the 35s have it messed up pretty good.
#38
Mpg
This a great thread. I'm alittle ocd about gas mileage. I check each tank manually(miles driven/gallons). My jeep when bone stock got 23.2 when I really was careful. However after adding larger tires/wheels, aftermarket bumber/winch, rock rails. My mpg dropped to 19.5. Not good imo. Does the flashpak effect the factory warranty? I'm verrrry interested in my mpg.
#39
I even took my jeep in last week for a recall about the hot oil light for the automatic transmissions. And I just told them right off the bat that I had a flashpac installed and if it would be a problem I could remove it. He replied shouldn't be a problem at all. He was more surprised that I already had a trany cooler installed.
