Superlift 4"
Old 06-29-2007, 09:53 PM
stevenisthug's Avatar
Default Superlift 4"
what else would i need to buy if the kit includes...
Kit Includes:
* Front Springs
* Rear Springs
* Front Superlift Superide Shocks
* Rear Superlift Superide Shocks
* Adjustable Front Track Bar
* Rear Track Bar Bracket
* Front Cam Bolts
* Front Brake Hose Brackets
* Rear Brake Hose Brackets
* Extended Front Bump Stops
* Extended Rear Bump Stops
* Front Bump Stop Spacers
* Rear Bump Stop Spacers
* Anti-Sway Bar Links
Old 06-30-2007, 12:12 AM
Rubimon's Avatar
Have heard negative things about the cam bolts. Some lower adj control arms would do you better! Just my $.02
Old 06-30-2007, 03:05 AM
usmcdoc14's Avatar
I no issues with mine when I installed them, no issues since either.
I would on the other hand recomend you go to someone who does know how to weld and have them beef up the welding on the resr track/panhard bar mount at the axle as the factory welds bring the suck. Add a gusset or 2 if you can while you are there.
Old 06-30-2007, 05:37 AM
2K1TJ's Avatar
Now's the time to order!!!!
4wd Hardware (4wd.com) has a sale going on. You can get 15% off one item. I got the Superlift 4" kit for $532 shipped!!! Reg. price is like $577 plus S&H!!
I'm not sure how long the sale is going on though, so you better pull the trigger soon .
Old 06-30-2007, 09:09 AM
oooh. i better jump on that. so with that lift i wouldnt need to buy new driveshafts right? ill be running 37"
Old 06-30-2007, 09:15 AM
2K1TJ's Avatar
If you have a 4 door you don't have to, at least not right away. I'm not sure about the 2 doors. You're rear d/s angle will be steeper if you have a 2 door. It's hard to say how these shafts are going to hold up to long term abuse. I just read today that Piginajeep's shaft is trashed (that came out wrong ). He has a 2 door.
Quick Reply: Superlift 4"
