Superlift help
New drive lines will allow for the greater flex in the joints connecting the front driveshaft to the transfer case. You may also need uppers to get it dialed in perfectly.
But all you need to do now is get the caster moved back to 4 or 5 degrees. You can have an alignment guy do it or remove the bolts and back out the control arms until the vibes go away. Making them shorter will fix your issues.
Wow, does no one listen? I told the shop 23 1/4" on the lower control arms and 6-7 degrees of caster. I get 7.2/7.4 caster and the arms are 23 1/2". I paid $130 for the alignment. WTF Im going back on Friday.
I know, I know, if you want something done right, you have to do it yourself.
I had it realigned to 6.7/6.8 degrees of caster (arms at 23 1/4") and its near perfect. I have a slight vibe at 60mph, but its barely there. I might go one more turn on the arms and see if the vibe goes away, but I could live with it and Im REAL picky.
The wandering is gone. The twitchy steering is gone. The steering wheel moving on bumps is gone. I like the Jeep even more. Now only if it had a HEMI.
The double cardan joint at the transfer case handles the drive line angle better than the ball bearing stocker. At 4-5inches of lift in frt ,the bearing joint and shaft are at it's limit. If your vibe or noise increases in the next week or two, it's that top bearing screaming. Wheeling it will make it come on quicker, just highway driving , may last a little longer. When your pinion was rotated down to acheive better castor it kicked the end by the T-case up, at least on mine it did. Waaayyy better drivability, but the stock shaft can't handle much more than where it was at before my control arms, it tweaked it enough to give me a vibe and noise, so I ordered a new shaft.
