Superlift help
Old Jan 4, 2009 | 05:43 PM
  #141
Dr.McNinja's Avatar
The jam nuts on the adjustable arms are huge. I just used a tongue and groove adjustable wrench. It isn't like you need to tighten them to spec or anything, because if the entire apparatus rotates, you have much bigger problems than a loose nut.
Old Jan 4, 2009 | 09:52 PM
  #142
mkjeep's Avatar
Originally Posted by TexsDream77
I want to go help him just because of where he is. But, it is a long drive. Next time I visit my family in MN I'm going to stop say hi and keep driving.
X2, I'd love to go to Montana! My wife and I have always talked about going. Must have been something about it in all those country songs I listened to when I was a kid. Ah, maybe one day. I got a BIGGASS 2 1/2 in crecent from my dad, no more worries about tightening big nuts now! Pipe wrench worked before that, I think that's the simple name for a tongue and groove. A big crecent will come in handy for adj trk bar jam nuts and bolts also.
Old Jan 5, 2009 | 10:49 AM
  #143
kntr's Avatar
GONETOSHOOT dropped of a pipe wrench and a crecent. The cresent wasnt big enough. I turned the arms in one full turn today. It took about 15 minutes. I just used a rachet strap to pull the axle back to get the bolts to go back through. Super easy.
Would it be a good idea to have the alignement checked again? When you change caster doesnt it affect toe also?
Old Jan 5, 2009 | 11:07 AM
  #144
mkjeep's Avatar
Your toe should be fine, it wouldn't have changed enough to matter. I wouldn't bring it back in, they might mess it up. You still gettin any vibes now?
Old Jan 5, 2009 | 11:41 AM
  #145
CJtoJK's Avatar
Just out of curiosity, what angle is the vertical center line of the front diff with 6-7 degrees of caster ?
Old Jan 5, 2009 | 12:40 PM
  #146
kntr's Avatar
I havent gone for a test drive yet. We are having a crazy snow storm right now and the roads are all snow packed. I wouldn't be able to tell if the vibe was gone or not. It was barely there before.
I did have to fix the boot on the driveline. The boot had pulled out from under the clamp. I took the clamp off and pulled the boot back straight and then put the clamp back on. It should be good to go for awhile. Ill have to watch it.
I might take it to the alignment shop in a month or so. Ill tell them to not mess with the castor and I want to watch them do the alignment.
Old Jan 5, 2009 | 06:20 PM
  #147
mkjeep's Avatar
I'm geometrically challenged I was lucky to read the angle finder right. I have to have a picture of what you want to figure that one out.
Old Jan 5, 2009 | 06:25 PM
  #148
mkjeep's Avatar
Think I got it figured out. Like this from the pass side / like this from the front l or maybe this \ if your on the driver side.
Old Jan 5, 2009 | 06:41 PM
  #149
JulietKilo's Avatar
good to hear! I think you should be good to go now. Dont worry about the angle now. Its probably about 5-6 and that is great! 4 degrees is stock so you are still better driving then stock caster.
Old Jan 5, 2009 | 06:42 PM
  #150
JulietKilo's Avatar
X2
