Suspension noise/rattle on bumpy roads?
Old Aug 30, 2010 | 11:23 PM
JKFORLOVERS's Avatar
Originally Posted by redrockin7
So I noticed this summer with top down and doors off most days that my ride on bumpy roads at least sounds like $hit. It doesn't ride that poorly at all, but it just sounds like it is kind of falling apart at the seems on most PA roads with bumpy sections, potholes, etc.
I don't know whether to call it rattle-y, bangy, or clanky, but it sounds like a jolting metal on metal sound over bumps at speed. I'm on 2.5" RC lift and 1" body lift.
Doesn't appear my shocks or any suspension parts are installed wrong or loose. I did the install (and did about 3 different setups 3 times) and have double checked tightness on everything multiple times.
It's been like this for probably 10,000 miles or so now though and it handles fine and like I said doesnt feel that bad, but sounds like crap. Like I said I've checked a bunch of things to no avail, so I am just guessing that is how it is supposed to ride when hitting (fairly) large bumps and potholes with any speed. If I drive the same bumpy roads at lower speeds I don't get near the terrible sounds. It's kind of like at speed the suspension/axle/etc. don't have time to react and 'travel' over the bumps and potholes 'smoothly' and quietly. At lower speeds it rides smooth on bumpy roads and offroad at low speeds it flexes just fine with no rattle/bang.
So, what else could be causing this? Just throwing out ideas, but:
-maybe my sway links aren't long enough? I have the TF quick discos for 2.5" lift so I dont think thats it, but like I said kind of like the axle isn't traveling as freely as it should when hitting bumps at speed? also my sway links sit kind of close to the spring (at least in my opinion)... I'd say there is maybe 1-1.5" (max) clearance between the end of my links and the spring. I don't think they can hit due to the way the sway bar would travel and cause the link to travel, but maybe it is too close for some reason and bumping together somehow?
-I think I left the rubbery isolater on top of the spring so its not like there could be a metal spring jamming on metal perch (but thats kind of what it sounds like)? Need to check that tonight.
-Could bad shock bushings be the cause of this? Mine look a little beat up but they aren't torn or excessively worn in my opinion? Or is this just the way it rides?
-My shocks seem fine for the most part and especially offroad with travel. It is not excessively bouncy, etc. Front driver is maybe leaking some fluid, but could this one 'bad' shock cause the entire thing to ride kind of crappy?
-could it be skidplates or something else loose? Are there obscure ones I am not thinking about b/c I checked the main engine/trans ones (sound coming from front end primarily) and they are tight, but haven't checked every single skid
Anyone?
EDIT: And when I say "at speed" I mean travelling a 45 mile per hour road at 45-50 mph, not speeding/flying around. However if I drove a 45 mph road at like 25-30mph, that is when it would be less noticable for example (which obviously not rrealistic to drive 20 under speed limit at all times)
My jeep did the same thing i purchased a track bar relocation bracket for the rear and it fixed the noise. Turns out my 2.5 rc bb kit made the rear axle out of line that much to make noise going over bumps its weird but it fixed it for 26. dollars. teraflex rear tb bracket.
Old Aug 31, 2010 | 12:21 AM
warlord's Avatar
crawl under and hit everything with a mallet to find the noise
Old Aug 31, 2010 | 05:58 AM
redrockin7's Avatar
Thanks for all the suggestions. I am definitely going ot jack it up and look for play in ball joints, check out the Us, and hit stuff to try to find a clunk. It also might just be its a big rattle trap with tube doors on (they could be part of rattle even if i dont really hear them as the primary rattle), spare tools in the back (thanks for the mention of that never occured to me), etc.
I'll find it yet!
Old Aug 31, 2010 | 06:07 AM
hcw3's Avatar
parking brake rattles on mine under the conditions you describe...check adjustment.
Old Aug 31, 2010 | 06:20 AM
Harbourone's Avatar
Mine had the same clunk on big bumps that youre describing and all 4 ball joints and both U joints were wore out badly.
Old Sep 1, 2010 | 11:08 AM
Slacka's Avatar
same noise on mine it started with little rattle then got worse sounds like dump truck going over bumps the shock bushings looked good but on further inspection the bushing had split in the shock . i took of bottom bolt in minute and seen prob. just throwing it out there cheap fix if it is the problem . hope this helps
Old Sep 10, 2010 | 06:29 PM
glocksrfun's Avatar
I have the same noise coming from her rear end also. They are tearing up my road and i didn't have access to my driveway yesterday. I'll check the bushings tomarow. Thanks everyone
Old Sep 11, 2010 | 08:20 AM
bhenneman's Avatar
May sound stupid buttttt I tore mine apart trying to figure out a rattle, clunk issue and it turned out a quarter fell through a drain plug hole and was sitting on top of the muffle. I couldnt believe how loud it was
Old Sep 11, 2010 | 08:35 AM
racer83l's Avatar
next time your driving over these potholes, touch and hold your brakes.... my rear brake pads rattle a litle bit over bumps.
I need to replace the shim things when I do my next brake job.....
Old May 27, 2021 | 06:37 PM
bpittman's Avatar
Did you ever find the fix?
