sway disconnect choice
Old Feb 12, 2011 | 03:05 AM
Rhino64's Avatar
Originally Posted by drivingfool
I'm getting into an AEV 3.5" premium on an 09 unlimited sahara, with ORE axle C's and 35s and I have to pick a sway disconnect. I'm leaning towards the Teraflex because it seems pretty simple, but they have 2 sizes to choose from, 0-3" and 4-6" so which is the right one for the AEV 3.5"?
All opinions welcome, thanks.
I'd reconsider the TeraFlex the bushing in mine only lasted about 5K miles. I replaced them with JKS which I like because you can get your sway-bar at the correct level. Seems on the TF the Zerk's bottom out in the area where you grease them. Yeah I know you can put small washers under them so you can grease them but why should you have to modify a new item. Unless they have corrected that issue I would stay clear of them. Just my 2 cents.
Old Feb 12, 2011 | 04:43 AM
drivingfool's Avatar
Originally Posted by stlfan06
Give JKS a look. Instead of undoing one side and worrying about securing it, the JKS ones disconnect on both ends, so you can take the whole disconnect off. Plus, they work for a larger variety of lift heights (2"-6"), I believe.
Hmmmmm, good info,thanks
Old Feb 12, 2011 | 04:53 AM
SLVR07's Avatar
This is what I have and I like them......and they are adjustable for length.
Old Feb 12, 2011 | 06:28 AM
JK jeepin's Avatar
I just got my JKS disconnects. They seem easy to install as well
Old Feb 12, 2011 | 06:41 AM
rexicon's Avatar
x9999 on the jks FTW
