Swaying jeep?
Old Dec 5, 2009 | 07:54 AM
  #21
captjay's Avatar
ok, i am sorry but my knowledge stops there. i dont know how to figure out if the y are installed corectly or out of adjustment. i have a guy i go to for that stuff. all i know is he adjusted the track bars front aand rear and that fixed my problem. sorry i cant help you any more on this
maybe some more people will chime in and get ya straight
Old Dec 5, 2009 | 08:14 AM
  #22
GoodysGotaCuda's Avatar
Again. BODY ROLL, or DRIFTING/WANDERING on the roll? Which are we talking about (original poster...)
People talking sway bars and caster in the same thread are in no way related. Two totally different areas in suspension.
Old Dec 5, 2009 | 08:22 AM
  #23
racer83l's Avatar
Originally Posted by explorer
i took the jeep for a ride and it is way diffrent. Before i had the front adjustable track bar and rear relocation bracket fitted, there was no swaying from side to side. It feels like the one tyre is smaller than the other. The tyres are all the same psi. Could there be somthing wrong with a coil? But surely you would see this when the jeep is parked on a level surfaface? Its like one tyre is flat and the other 3 are not.
post some pics of the entire JK and then various pics of the suspension set up..
Old Dec 5, 2009 | 08:28 AM
  #24
explorer's Avatar
body roll. If you stand next to you jeep and put you and on the windows and push it softly from the side it rocks. Now that is what it feels like when i drive. It rocks the most when i turn but also in a straight line
Old Dec 5, 2009 | 08:29 AM
  #25
explorer's Avatar
Right now there is a big storm outside. Once it stops i will take some pictures and post them
Old Dec 5, 2009 | 08:35 AM
  #26
captjay's Avatar
well in that case, IMHO i say Nature of the Beast
Old Dec 5, 2009 | 08:41 AM
  #27
sin52's Avatar
Originally Posted by sin52
Sound like when you drive with the swaybar disconnected. the front end rocks like a motorboat and the rear end follows.
Might not be the problem but same characteristics as a swaybar disconnected from your explanation.
Old Dec 5, 2009 | 08:42 AM
  #28
racer83l's Avatar
For what its worth, my JK is lifted close to 4" and I run 35's, my jeep has almost zero body roll, if you grab a hold of it and try to rock it side to side, it barely moves.. I can (and do) whip my JK around ramps, I LOVE the way it drives on the road..
I also have AEV's suspension that was tested on a slalom (and Teraflex's super slick S/T sway which is firmer than stock), and I swapped from OME's coils because I wasnt really happy with its ride either.
i wouldnt say its the nature of the beast, maybe just the nature of that particular suspension setup. Tera's S/T sway will help in this situation, it helped me when I was running OME coils
Old Dec 5, 2009 | 08:48 AM
  #29
explorer's Avatar
I get what your saying but why now? I got this over 6 months ago. I was sick of the way it handled so i was told to do the front adjustable track bar and rear bracket(i know this shouls have been done in the bigining) i then also had longer rear links fitted and the old rear ones were moved forward. Thats when it all started to go bad. I will get lower adjustable control arms next week and i know this will make my jeep track straight and not pull to the left like it does now. But thats not going to stop this rocking effect
Old Dec 5, 2009 | 08:52 AM
  #30
captjay's Avatar
ok sorry, reword nature of the beast, yes nature of the particular suspension.
you ask well why now? maybe one option is your suspension i guess would say settled and has become more loose so in turn you get more swaying from your springs
i honstly have no idea, just throwing an idea out there that maybe someoen else can elaborate on
