Swaying jeep?
Today i took out the longer rear swaybar links and moved the origanal rear ones back from the front and installed the origanal front ones back. My swaying problem is gone.
I am getting the front lower ajustable control arms fitted on saturday( Thank you David Northridge 4x4 who assisted me all the way in South Africa
) from the alignment specs they picked up that my thrust angle is out on the rear axle
Will the new control arms help to get this right? Last question... Should my final alignment after the control arms be the same as stock or would you suggest more toe out? more caster? any suggestions please.
Thank you to everybody that responded
Will the new control arms help to get this right? Last question... Should my final alignment after the control arms be the same as stock or would you suggest more toe out? more caster? any suggestions please. Thank you to everybody that responded
If you want to cut the body roll down, upgrade the front swaybar to one of these:
http://www.teraflex.biz/products/jk-s-t-swaybar-4.html
Yes you will have to remove that e-disco unit, however this system is more reliable. You just turn a knob to disconnect the swaybar. When it's locked in "Street" mode you'll find that this bar is stronger that a stock swaybar.
