Tack weld u-joint caps
Old Aug 4, 2011 | 01:56 PM
medic_23387's Avatar
Default Tack weld u-joint caps
Can someone post a pic of how they tack welded their u-joint caps.
Old Aug 4, 2011 | 05:50 PM
Someone, anyone?
Old Aug 4, 2011 | 06:00 PM
mkjeep's Avatar
Just FYI, when you tack weld u-joints, you super heat the grease and needle bearings, effectively shortening there life. Plus if you have a u-joint fail on the trail, kinda hard to grind the welds off, unless so equiped. This may be ok for a trail rig only, but if its your daily driver that sees alot of road miles, I wouldn't recommend it.
Old Aug 4, 2011 | 06:04 PM
mkjeep's Avatar
A better approach would be to carry a spare u-joint in your jeep for daily driving and to get a spare set of stock axles for the trail. Thats what I do anyway.
Old Aug 5, 2011 | 03:59 AM
Been looking for a spare set of axle shafts but can't seem to find any
Old Aug 5, 2011 | 05:26 AM
crazyhorse02's Avatar
Just run your U-joints as is for now and if you lose a cap or blow a joint, just replace the joint with circle clips. Problem solved.
Old Aug 5, 2011 | 06:44 AM
I can't find any joints that aren't super high that have full clips
Old Aug 5, 2011 | 08:22 AM
Norm's Avatar
I have done mine. My rig is not a DD. When (not if) my axle fails i only plan to replace parts not try to fix them. So the added insurance of the caps not coming off is worth it to me.
-Clean area
-Tack all 4
-Paint
Pretty simple and it's hot for 1 second.
