Tail gate door changed to pickup tail gate
Old Jun 10, 2008 | 05:01 AM
sspronin's Avatar
Default Tail gate door changed to pickup tail gate
Hi all has anyone ever make there rear tail gate door go done like a pick up tail gate insted of a swing door? I think it would be nice to be able to leave the tail gate down in some situations. Just a thought.
Old Jun 10, 2008 | 05:51 AM
ARubicon's Avatar
I have had that same thought. I could not leave it down while driving due to the tire carrier, but I think it might be a better set up.
Old Jun 10, 2008 | 06:48 AM
Yucca Patrol's Avatar
It sounds like it would be a complicated mess to get it worked out.
The quick and easy solution might be to install the Brett Woods tailgate shock kit to keep the tailgate open. In some rare situation where you need it, you could drive with the tailgate open with that shock in place.
Old Jun 10, 2008 | 07:44 AM
sspronin's Avatar
you are right you would have to relocate the spare tire. I dont think it would be to hard to do. I cant weld, but I figure you would have to reinforce the flimsy sheet metal and put some hinges from the bumper to the door, and add guide lines to add extra support.
Old Jun 10, 2008 | 07:47 AM
sspronin's Avatar
The thing is I go camping, kayaking, yard work and things, and use my JK like more of a pick up. I know why not get a pick up, but I like jeeps. But anyway it would be nice to lay the tail gate down to slide a kayak in, fire wood, lumbar, etc. etc. It is a pain trying to open shut the swing door with things stick out.
Old Jun 10, 2008 | 07:48 AM
SGT.'s Avatar
interesting idea......
Old Jun 10, 2008 | 08:06 AM
[N]UGE's Avatar
Some extra leg room woul dbe nice for sleeping in the back
Old Jun 10, 2008 | 08:47 AM
scouter4life's Avatar
What about a roof rack? for most of those items, I think a roof rack would do the trick. Might be easier and ultimately less expensive than what it might take to convert the rear gate.
Old Jun 10, 2008 | 09:31 AM
And if a rack won't do, a small utility trailer is quite cheap, probably cheaper than the engineering and custom work to do a fold down tail gate.
Old Jun 10, 2008 | 09:39 AM
cdecker79's Avatar
I like the idea of a fold down tailgate too. Eventually I plan on getting an aftermarket rear bumper with tire carrier (that locks in the open position). It would be great to lock that open and sit on the tailgate. I have a 2-door, and any its almost impossible to use the back as a "seat" when I have all my gear loaded.
