Take muffler off??
Old Aug 13, 2009 | 03:29 PM
JKjunkie2009's Avatar
Default Take muffler off??
Has anybody just taken the muffler off? I think it might be a tad illegal, but im thinking about doing it....Is their any problems this could cause? Has anybody done it?
Old Aug 13, 2009 | 03:31 PM
guybergeron's Avatar
i ran it muffler less for .. 10 minutes. i then put a streight true magnaflow. i think the sound is not that much different. just try it. the hardest thing is to remove it from the rubber... thingies.
Old Aug 13, 2009 | 03:40 PM
wouldent cause any engine problems would it? Im workin on it right now
Old Aug 13, 2009 | 03:47 PM
falconfixer's Avatar
I'm not sure but I think the engine needs a cerain amount of backpressure to be efficient. Taking the muffler off might make it sounds cool but degrade your performace.
Old Aug 13, 2009 | 04:01 PM
nikbass's Avatar
I don't know I think that the stock muffler may choke out some power.
Not a big deal but I'm suspicious.
Old Aug 13, 2009 | 04:11 PM
its off and it sounds awesome!! it just sounds deep. Basically sounds like it looks!! I deffenatly think im going to keep it off..... until my next inspeciton that is.....
JPop's Avatar
Not back pressure, but an appropriate pipe diameter to assure velocity without restriction. A large can creates a larger heat sync, and loss of heat contracts exhaust gas, slowing it down.
Old Aug 13, 2009 | 04:24 PM
so Jpop, are u saying theirs not enough back pressure to do this? or am i in the clear?
Old Aug 13, 2009 | 05:36 PM
JPop's Avatar
Back pressure isn't an issue nor solution. You put a fat pipe on your JK you'll lose exhaust velocity, just like the tuner crowd. Then someone from that crowd decides that it's "back pressure" that needed, it's not.
So as long as you run the stock size 2.5" pipe you'll be cool.
Old Aug 13, 2009 | 05:49 PM
fuzzy1940's Avatar
Default mufflerless
Your right it does sound cool, But so does my Gibson, I'ts pretty loud, to but it might just be my imagination but I think it's mellowing out abit, Most runs I've been on require Spark Arresters in the wooded areas. I.E mufflers.
I actually lost about 1-2 mpg with the Gibson, Small price to pay -- lol.
