Teraflex Big Brake kit
I have a 2012 but when I purchased the kit I went all out and upgraded the master cylinder as well. It's been a while since I did the swap (2 years) but I compared the two cylinders side by side to include internally as much as possible and at the time the one you get from TF still had a much larger piston compared to stock.
Teraflex told me that I have to "cycle" the ABS by panic stops on gravel road or wet grass about 5 times to get the air out of the ABS then bleed and it should be okay. I will do this once my Jeep gets out of the shop.
Anyone have experience with the TeraFlex Big Rotor Kit.
From what I understand does not affect the hydraulics of the brakes but increases the the mechanical advantage by increasing the leverage with the bigger rotors.
