Teraflex Sliders
Old Jun 19, 2007 | 06:33 AM
Gear's Avatar
Looks good. Does anyone know if there will be clearance issues with larger tires. I have read about people cutting down the length of the stock rubicon sliders. Also how far do they stick out 3"? Anymore photographs I would like to see how they attach underneath. OH and did you weight them by chance.
Thanks
Old Jun 19, 2007 | 06:36 AM
mlg's Avatar
mlg
Looks good! What wheels are you running?
Old Jun 19, 2007 | 07:51 AM
BARNO's Avatar
NMJK - How much for the set? I'm looking at getting some! Thanks.
Old Jun 19, 2007 | 09:17 AM
RedRockJK's Avatar
They are about $400 for the set. Last I checked, 4wd.com had them in stock.
Old Jun 19, 2007 | 09:52 AM
BARNO's Avatar
You're right! Part number: 004637300 Thanks!
Old Jun 19, 2007 | 10:32 AM
nmjk's Avatar
No, I did not have to modify the flares, they fit snug.
If there is any clearance issue it would be with the body, not the sliders. There is a piece of body panel that joins and kinda sticks back towards the rear tire. That would be the problem.
They stick out about 3.25" Enough for you foot to get a good hold.
Underneath there are 3 1/4" bolts that go up into the tub. You will need a long drill bit to get through.
They are fairly light, they are made out of aluminum.
I forgot the make of the rims, they were the only 5-5 16s that discount could get back in november.
Old Jun 19, 2007 | 10:34 AM
nmjk's Avatar
I got them through Quadratec. I would double check if anyone says they have them in stock. I waited nearly 6 months so they have to be fairly back ordered.
If you do get them, make sure you lube the sert tool before each use or it will not last.
Old Jun 19, 2007 | 05:32 PM
dhoffroad's Avatar
hey thanks for the pics. but can you get a pic of the rear where they stop at the wheel well ?? and maby a pic from the underside ??
Old Jun 19, 2007 | 05:52 PM
RedRockJK's Avatar
Originally Posted by dhoffroad
hey thanks for the pics. but can you get a pic of the rear where they stop at the wheel well ??...
Here's the closest thing I have. I took these pics in person and got a good look at them. I didn't want a tube style slider, and after seeing these I was sold. They are definitely shorter than the stock Rubi sliders, so you wouldn't have to worry about trimming them. The body is closer to the tires than the Teraflex sliders are. IMHO they are the perfect length. Not too short and not too long.
Old Jun 19, 2007 | 06:51 PM
BARNO's Avatar
Here's what I have if it helps.....
