Thinking of going with Rancho XL9000's Shocks
Post a link up.
If it is leaf packs, it is for the CJ/YJ platform most likely.
2" SPORT P/N's
RS66108BR9 2 door with 9000's
RS66108BR5 2 door with 5000's
RS66109BR9 4 door with 9000's
RS66109BR5 4 door with 5000's
Make sure you get the right P/N they are different systems.
2" SPORT P/N's
Correct image/P/N.
The coils are used up front and the spacer in the rear. Often times Amazon descriptions are incorrect.
hey Matt , I just got the rs 9000xls just fronts are on as of today , but I was wondering ? Will these (999328 rear) and (999326 fronts ) work ok with this kit im concidering buying down the road here ?
this is a 1.5 rk kit and on two door it says up to 2.5 in front on two door & 1. 5 in rear . I have a psc mid bumper @ 130lbs up front will these shocks I have be ok
again 999326 / 9993328 ? because im stock rubicon right now on my two door and these new ones said 0-2 Im upgrading parts slowly , as I can afford to do it this way & not all at once you know ?
thank you
just the 1.5 kit from rock krawler
only issue I could see is if it does go to 2.5 up front maybe adding a winch would drop it below that's if I even lift it up ! I might not
thank you
thx rancho dude.
I got the kit for $$350 minus the rebate so all in all a good deal. Now to put the pucks and springs on is that better do do at a garage or can I do it muhself?
Do I have to drop the axles at all? Do you have any inskructshunal videos on how to do this?
With the 2" SPORT no need for a new drive shaft or exhaust mod on the 2012+
With the RK 1.5, you will most likely need to upgrade your shocks to a longer length (29/30 the last two numbers on the shock for the JK application). Sorry about that. :(
You can do this install at home easily, it does help to have a friend and no need to drop the axle either.
NO video at this time, we are (hoping) to make more DIY videos this year.
thank you
thank you
thx rancho dude.
thx rancho dude. I got the kit for $$350 minus the rebate so all in all a good deal. Now to put the pucks and springs on is that better do do at a garage or can I do it muhself? Do I have to drop the axles at all? Do you have any inskructshunal videos on how to do this?
One thing I will add though is if you have considerable mileage on your current rear springs consider replacing them for the install. I have about 90k on my rear spring (59's) and post install of the pucks my rear sits 3/4"-1" lower than the front. It really doest help I always have about 100lbs in the back of work equipment.
Mr Ranch dude something to consider as an upgrade package! Rear Springs!!!
I mention this ALL the time, actually.
I did the install myself. 3 hours for the rear on my own. 2 hours for the front with a buddy. Very easy to do, just read the instructions, but once you get to it you really won't need them.
