Those with D60's
Old Feb 27, 2015 | 06:35 AM
  #61
Kingfrank's Avatar
It's amazing what you learn on the forums. I know why my brake light is on.
Old May 12, 2015 | 03:59 PM
  #62
Waldo_88's Avatar
Originally Posted by 2climbbig
I definitely recommend you get an 08 to 2010 rear sterling. The issue with an older sterling will be with the rear wheel sensor. With an 08 or newer, you get to keep most everything. You just have to replace your hanger (which seats the sensor) and add a tone ring ($10) or replace your hub with a newer one that comes with the tone ring.
Replace the hanger with what?
Old May 12, 2015 | 04:26 PM
  #63
Invest2m4's Avatar
He's talking about the hanger the brake caliper mounts to. It's actually on the 2011+ axles, but it's a cutout of you wanted to try and run the factory sensor setup (ford factory). Far easier now to use the artec kit as it will also place the sensor where it needs to be and let's you reuse the jk sensor.
Old May 12, 2015 | 09:02 PM
  #64
dog's Avatar
dog
tag for info, thanks for the wealth of knowledge here.
Old May 13, 2015 | 03:45 AM
  #65
Maertz's Avatar
According to Pirate: "Axle Flange Bolt Pattern: 8 on 3.523", 1/2" holes, bolts are 1/2-NC13x1.5"" but other sites confirm 8x6.5
Also axle shaft bolt pattern and actual rim bolt patterns are different. The 8x3.523 is the full float axle shafts bolts. Rim can still be 8x6.5
Old Sep 28, 2015 | 11:25 AM
  #66
Colorblindspy's Avatar
A lot of information here. Has anyone put this into a spread sheet as a build list for either the 60 front/rear or the 60 front 14b/sterling rear?
Old Sep 28, 2015 | 11:33 AM
  #67
Invest2m4's Avatar
I wrote up a fairly inclusive thread on JKO for the D60 front: 2005+ Super Duty D60 Axle Bible - JKowners.com : Jeep Wrangler JK Forum
Many guys over there that have built one or are in process. Reply to that thread with questions and you'll get plenty of insight from others.
Old Sep 28, 2015 | 01:59 PM
  #68
mistasparkl's Avatar
^ That is great info.
Old Sep 28, 2015 | 02:25 PM
  #69
TweakJK's Avatar
My experience with 12+ speed sensors. Jeep is a 2013 2 door auto
1 speed sensor will make the speedo work.
3 speed sensors will make the auto tranny shift and removes CEL
4 is obviously ideal
Right now I only have 3, have not gotten a chance to finish the 4th. Been too busy wheeling. Not having that 4th has been annoying. Occasionally at 25-30mph one of the sensors will drop out and cause limp mode, which really sucks when you are on 5.38's. Slows down real quick.
I have been using the autostick feature and keeping it in 1st or 1st and 2nd, and it does great on the trails.
Old Sep 29, 2015 | 08:12 AM
  #70
2climbbig's Avatar
Last you and I spoke, you were having issues with the auto shifting gears... did you solve that problem?
