Time to regear, What to do?
2010 2dr, 3.73 6speed, 35" KM2s and 2.5" TF Coil Lift...mostly local driving, little hwy use and minimal off-road. I can get by with current setup but I just want to get back near factory power. I doubt I'll be upgrading to 37" tires anytime soon but you never know a few years from now.
4.56 or 4.88? What brand of gears? Best place to purchase? Thanks.
4.88 will be a bit better, while still having decent freeways rpm's, and will work for 37's.
5.13 will have the rpm's a bit high if you do a lot of 80+ driving, but will situate you perfectly for the 37's.
So what are your freeway habits, and do you really want to regear a second time when the 37's go on? You are talking about 37's now, so you may as well just plan on them going on...
The brand doesn't appear to matter much, as they are all coming out of the same overseas factories. Compare price and warranty and pick what you want. And if you are not installing yourself, talk to your shop to see what their policy on provided gears is. Some will not install, some will not warranty, or will provide a better warranty if they provide.
And remember that you are seeing re-gear advice for both auto's and manuals. They have different gearing needs, so note which bits of advice you are taking.
An Auto with 5.13's and 35's = roughly 2380 rpm @ 70mph
For a Manual with 5.13's, you would need to run 43" tires to get the same rpm.
That is just the straight rpm numbers, you still have to factor in the HP and auto tranny slippage and whatever else.
And the transmission ratios just for the heck of it:
42RLE—Automatic, Four-Speed Overdrive
Gear Ratios 1st 2.84
Gear Ratios 2nd 1.57
Gear Ratios 3rd 1.0
Gear Ratios 4th 0.69
Gear Ratios Reverse 2.21
NSG 370—Manual, Six-Speed Overdrive
Gear Ratios 1st 4.46
Gear Ratios 2nd 2.61
Gear Ratios 3rd 1.72
Gear Ratios 4th 1.25
Gear Ratios 5th 1.00
Gear Ratios 6th 0.84
Gear Ratios Reverse 4.06
Originally Posted by Bingbola
Honestly I can never get so much of regearing topics because I am in the process of getting them too and I always love to hear different opinions and why they pick the gears they do. It's a big decision for all jeepers and a mod that definately needs to be done.
To the original poster: I plan on upgrading my gears down the road but Its alot of coin that I'm spending on other parts. How bad was acceleration with 35"s and 3.73 on your 6sp? I'm ordering a 2.5" lift and some 35"s but it probably will be a year before I get around to regearing.
Is it bearable?
Thanks!
Is it bearable?
Thanks!
