Tires?
Old Oct 13, 2010 | 09:45 AM
Olean NY Jeeper's Avatar
Originally Posted by Jcon27
So if I Put a Dana 44 on the front end it would have no problem with 37's
You would still have to reinforce some things but better than dana 30. Pro-rock would be the way to go.
Old Oct 13, 2010 | 09:48 AM
genesbro's Avatar
Default not bending but twisting
Bigger tires don't bend the axles, it causes them to twist more as torque is applied via the gears. That is why you hear about the number of splines on axles. Usually more splines means more diameter and more strength, less twist, less likely to break.
Old Oct 13, 2010 | 09:57 AM
Jcon27's Avatar
So overall, what would be the best route to take? If I put a Dana 60 on it would I have to replace both Axels?
Old Oct 13, 2010 | 10:09 AM
genesbro's Avatar
Default ultimate
My dream setup if I had the money would be the dana 60s already cut and preped for the jk I think called rockcrawler axles. With those axles and an engine swap you would have a super trail rig that would go anywhere with no worries of breakage. A little less money would get a 60 rear and 44 front and be almost as good. Of course you would have lockers in both ends. ARB or electric would be best if you do any wheeling in the snow.
Old Oct 13, 2010 | 10:23 AM
Jcon27's Avatar
With a long arm suspension kit I'm guessing?
Old Oct 13, 2010 | 10:44 AM
genesbro's Avatar
Default sounds good
That sounds like a good choice. Here is a club that I think you would like to be a member of. They host the Jeep Jamboree in the Palo Duro Canyon each year and also the challenge run that just happened last month. Jeepexclusive.net The members have lots of experience and can probably give you a lot of great information and take you on some great trails.
Old Oct 13, 2010 | 11:07 AM
Jcon27's Avatar
Outside of Amarillo, Texas? I actually have some friends who annually drive that trail! Thanks
Jcon27's Avatar
I used to live there before I moved for college!
Old Oct 13, 2010 | 11:14 AM
genesbro's Avatar
East of the state park on a private ranch is where they have the run. The club has to follow very strict rules for access to the place. Mentioned it since I saw that your location says that you are there. Wish we had something nice like that around here.
Old Oct 13, 2010 | 11:30 AM
Jcon27's Avatar
I prefer the Canadian river. Less regulations to follow. But I will look into the jeep jamboree
