tires
Old Oct 10, 2012 | 06:03 AM
Rich30000's Avatar
Default tires
Can I run 35s on my jeep jk with a 4 inch rough country lift as is. ?
Old Oct 10, 2012 | 06:20 AM
Juice Box's Avatar
I wouldn't recommend running anything on a rough country lift. Especially your Jeep. Just my opinion. :/
But the answer is yes, if your rims have backspacing or you install wheel spacers.
Old Oct 10, 2012 | 06:37 AM
holmes4x4's Avatar
Anything above a 2.5" lift you can run 35s no problem. IMO if you are running 4" RC lift I would look into running 37s
Old Oct 10, 2012 | 06:59 AM
KY JK's Avatar
I have a 4" and need 37's. Well after the long list of upgrades needed to run them!?
ID:	376343 Click image for larger version
Old Oct 10, 2012 | 07:01 AM
Nwapache's Avatar
^^^ this 35's all day long
Old Oct 10, 2012 | 04:54 PM
Rich30000's Avatar
Tell me why you dnt like rough country. ? I read a lot about rc lifts and some that has happened. What would you recommend I replace my shocks or springs the lift has done great so far .
Old Oct 10, 2012 | 05:03 PM
BigSteve's Avatar
If you search enough you will find people that hate every lift set up. There is nothing particularly wrong with rough country, it is that most people feel like they are at the lower end of the lift companies. Some people also don't like the design of the lift and the joints they use. Personally I think that if it works for you, doesn't break, installs properly and fits your budget then it must be a pretty good kit.
Old Oct 10, 2012 | 06:12 PM
Nwapache's Avatar
^^^ and this
