Too Much Caster??
You don't have nine degrees of caster. Caster cannot be measured with an angle finder. Angle finders can only be used to make sure caster is equal on both sides and that's it. Because of steering axis inclination, caster has to be measuerd in an arc and angle finders only measure straight angles. If SAI was at zero, then an angle finder could be used, but it is not. You need an alignment machine or a manual caster gauge at the very least.
If you cant measure caster with an angle finder, I think someone should edit that in the DIY thread that talks about adjusting caster.
If you lengthen the Control Arm to raise the angle finder by one degree, are you not actually adding one degree of caster?
No, you are not.
I think it should be noted that what Rob is referring to is a more accurate way to measure caster vs. the way most of us do it - and in that regard, what he was saying was correct.
The way Rob is referring to is like in this video: ehow.com/video_2327627_tips-adjusting-caster-measurement.html
Isn't that right Rob?
If you cant measure caster because it is an arc that makes sense, however, if you connect the two ends of an arc, would that not lead to an agle?
Would you be able to measure an angle somewhere on the rig, or is that what the 100000 dollar alighnement machines do?
htt p://5xracing.com/i-127089-fastrax-camber-caster-gauge.html
These have been around for close to a hundred years. Nothin new.
