torque wrench question?
Old Jan 19, 2010 | 08:53 AM
Olean NY Jeeper's Avatar
Default torque wrench question?
I was looking at torque wrenches at both tractor supply and autozone. It seems like there are two kinds, one expensive one cheap. The cheap one is not a rachet and has a needle. The more expensive one you need to adjust to desired torque and is a ratchet. This may be a dumm question but can I just buy the cheap one or do I need to buy the more expensive one. Thanks for your answers. Will be using to install lift, skids, and do diff oil changes.
P.S. I am not sure if this is the right forum but since I am going to use the torque wrench to modify my vehicle, this seems to fit. if not please move to correct forum.
Old Jan 19, 2010 | 09:01 AM
ssunde1's Avatar
Get the ratchet style that u adjust by turning handle to desired torque setting. This is one of the most important tools u can have IMO
Old Jan 19, 2010 | 10:06 AM
Mark Doiron's Avatar
X2. Reason is that with the pointer kind you have to get your head into a good position to read the needle. Trying to torque some of those suspension bolts to 125 foot-pounds is tough enough, without adding in the complexity of where your head must be placed and turned.
Old Jan 19, 2010 | 10:08 AM
Ericker's Avatar
Harbor Freight sells a ratcheting one for $20. I can't comment on quality as I have never used theirs. I've been using the one with the needle but sometimes I need my neighbors help in torquing things to the right amount because of the aforementioned head position thing.
Old Jan 19, 2010 | 10:16 AM
BurqueSahara's Avatar
Default buy a good one
I like the ratchet type for the reasons mentioned above. also, don't cheap out on this purchase. I tried a Harbor Freight one, and it is really sensitive to the way you pull on it. If you are pulling the slightest bit to one side, it won't ever click. I went to Lowe's and dropped some cash on a good torque wrench and it is well worth it. Weigh whatever the torque wrench cost is against something coming loose while you're traveling down a highway or when you're way out on some Jeep trail, and the cost is worth every cent.
Old Jan 19, 2010 | 11:03 AM
IcyFridge's Avatar
I just got a nice one with the twisting handle for Xmas. It serves its purpose!
Old Jan 19, 2010 | 11:40 AM
JK Rocker's Avatar
With tools, you always get what you pay for. Don't skimp on them... especially a torque wrench. You need to have confidence that the work you do is done correctly. Your life or someone else's could be at stake.
Old Jan 19, 2010 | 11:54 AM
Points well taken, the expensive one it is.
Old Jan 19, 2010 | 01:00 PM
JeepingNet's Avatar
I've learned with tools the hard way to always buy more than you need now because down the road you will need it.
I have both.. the needle version is a waste of money because it is hard to see and even harder to get accurate results.
Old Jan 19, 2010 | 01:02 PM
NorthRiver's Avatar
Another thing to consider is that a torque wrench is most accurate in the middle of its range.
Meaning that if its rated at 10-100lbs it'll be most accurate at about 45-50lbs.
You're best bet,although expensive is to have more than one torque wrench.
I've got three. One is for in-lbs,one is up to 100 ft-lb and the other is up to 200 ft-lb.
