Torque wrench question
Old Jun 10, 2009 | 07:32 AM
RedneckJeep's Avatar
Originally Posted by Ryanc
Not been serviced, was calibrated about 3 months ago. As for servicing, what sort of lubrication do you use, basic oil like on gun levers, etc.
I've always just used a light coating of wheel bearing grease. You want something that's gonna stay in there a while.
Old Jun 10, 2009 | 07:45 AM
Ryanc's Avatar
This wrench states 10-100ftlb. Is it true that if I am torquing something at say 96 ft lb it would not be accurate or not "click" at all. I have read, that though the wrench states 10-100, its useable range is like 20-90.
Old Jun 10, 2009 | 07:53 AM
Really? I've been at this game a long time and that's one I've never heard. In fact, I've set torque wrenches at their absolute max....which is usually a tad beyond the marked max and they've worked everytime.....course I don't recommend doin it. All the ones I've ever used will go at least to their marked max. Never heard this one before at all.
Old Jun 10, 2009 | 08:10 AM
Ryanc's Avatar
Yeah, I thought that sounded kind of strange, thats why I asked.
Old Jun 10, 2009 | 09:18 AM
ronjenx's Avatar
It has long been the practice in the military that the bottom 20% of the range is not to be used. The rest of the range, right to the top, is fine. The setting should never be above the highest setting on the vertical scale, and not below the lowest setting on the vertical scale for storage. This is published in the Technical Order which governs torque wrench usage.
Like I said before, most people out there don't use a torque wrench in the most correct way, if they use one at all.
Old Jun 10, 2009 | 09:42 AM
falconfixer's Avatar
Aircraft Maintenance 101 dictates how to use a torque wrench. I, along with every other crew chief is taught to max it out, click it like stated, run it down to lowest setting, run it back to max, click it again and do this 6 times. Also been briefed that the bottom and top 10% of the torque range is not useable/reliable on a given torque wrench.
I figure if that's they way we're supposed to ensure proper torque on a $2M motor in a $30M aircraft, I'll use that practice on a Jeep
Old Jun 10, 2009 | 01:58 PM
Ryanc's Avatar
How are you guys maxing out these wrenches, on a stationary bolt or something?
Old Jun 10, 2009 | 02:02 PM
Coupla ways. Ideal is to have a junk impact socket welded to a plate of steel that is bolted to a workbench or something. Its gotta be something that won't grenade when you start cranking 200ft lbs of torque. Another method, if one is so inclined, is grip the penis part of the torque wrench in a vice and break torque.
And yep, a stationary bolt works too.
Old Jun 10, 2009 | 03:33 PM
ronjenx's Avatar
Is post #4 invisible?
Old Jun 10, 2009 | 05:53 PM
Ryanc's Avatar
Sorry, wasnt paying attention.
