Towing
Old Mar 11, 2013 | 08:37 AM
tumblehome's Avatar
Default Towing
Getting ready to make a long excursion in a 2 door, 2012 JK with 3.73 gearing and a Curt class lll hitch. I will be pulling a 1900 lb, 13 ft trailer that has a sway bar installed. Should I make any changes to the JK (that won't break the bank) that will make this journey less stressful on the jeep? Thanks in advance.
Old Mar 11, 2013 | 09:08 AM
AirJordan613's Avatar
Just keep it under control, not too fast. I tow 2000 lbs with my '08 2DR and it handles it well. I added an auto trans cooler but having a 2012, I believe you already have one if you went with the auto.
Old Mar 11, 2013 | 09:20 AM
jeeperjkjeeper's Avatar
Auto= Tranny cooler for sure
I use 75w140 Amsoil Synthetic Severe Gear in the rear diff for towing.
Old Mar 11, 2013 | 09:39 AM
cis911's Avatar
Yes sir, 2012 -2013 automatic come with transmission cooler. And take it slow. The Jeep will do fine
Old Mar 11, 2013 | 10:02 AM
tumblehome's Avatar
Default towing suggestions
Thanks for the responses. I do have the automatic. Do you think the factory shocks/suspension are up to the task, will there be sagging issues?
Old Mar 12, 2013 | 06:40 AM
RattleDogUSA's Avatar
You should be fine, but towing with the 2dr sucks. I highly recommend trailer brakes.
I know there is cost involved, and alot of people will say "aw hell, you don't need nun-o-that crap!" but it could save your rig and trailer (maybe even life?) from an accident.
Story time! I was towing a 1800 lb trailer from Phoenix to Ogden, UT and I had upgraded the small trailer to have brakes. I was in a 2011 Ram 2500. Easy peasy tow, right? Well, I hit some unexpected ice along the way and started to slide. Truck brakes did very little and I started to spin. Luckily, I had the trailer brakes and manually engaged them and let off on the truck. The increased friction from the rear pulled me straight, allowing me to then stop using the truck.
I tow everyday with my JKUR and a 1800 lb trailer. I know that's fairly light but I'm sure that trailer brake has saved my butt several times, especially in rain/snow.
Old Mar 12, 2013 | 06:44 AM
cis911's Avatar
The springs and shocks will be fine just don't be surprised if the rear of your Jeep drops an inch or so after putting the load of trailer onto the hitch.
Old Mar 12, 2013 | 06:50 AM
NewOldSchool's Avatar
I don't think they all do. Only if you get the towing package will it come with cooler. When i bought my '12, I noticed that most on the lot did not have the towing package added to them. Mine and another one were the only ones that had it. Towing package was only a couple of hundred dollars more, but well worth the price in my opinion. I looked for a few months until i found the my crush with all the options on it, including the towing package.
Old Mar 12, 2013 | 07:23 AM
boxcar's Avatar
I pull a 16' landscape type trailer for work somewhat often. I know a few times it`s been over the stated max load. I have a jku w/ 1/34 lift on it using a curt hitch w/ a brake controller. You will drop atleast 1-3 inch`s from the load. Try and load front/center, not all of it on the hitch but more importantly not heavy on the rear. Just go slow, if you start to sway, let off on the gas. As for the brake controller, unless you tow alot of heavy loads it`s a waste of money. Mine is so sensitive it locks up the trailer if I dont have a load. Maybe the big buck ones are better but honestly I doubt it`s worth it unless you tow alot.
Old Mar 12, 2013 | 07:43 AM
Tych23's Avatar
U can get trailer brakes that are adjustable so u can control how much they grab, and if u have no load u can adjust it so it won't skid like u say
