track bar bracket broke
Im sure if you weld it up or have someone do it for you, it will be stronger then stock if all sides where it touches the axle get welded, and maybe even add some metal to brace it up.
Even if you dont weld or know someone that does, It shouldnt cost that much to have a shop do it for ya.
This is a big problem with bolting a bracket to the axle. The increased leverage created is too much for the OE bracket on the axle. Never install a trackbar bracket on the axle for anything you plan to take offroad. You got lucky you did not do more damage.
I would call Skyjacker and let them know what happened as a result of the design.
The stock rear track bar braket brock today. I have a 2.5" skyjacker lift w/ 35s on a 2 door. The rear bracket where skyjackers relocation bracket bolts up broke where it is welded to the axle. After inspection the stock bracket has welds on 3 sides. The outside weld had not fully fused with the bracket. The weld litterally seperated from the bracket.
Here is the bad part. The service manager said Jeep would deny the claim because it is lifted. Then he told me my drivetrain warranty will probably be voided due to the larger tires.
Any one have any experience with the Magnuson-Moss Warranty Act?
Yours is the 3rd I have heard of on a JK. 1 on the rear bracket, and 1 on the front. Both had "riser" brackets. I saw pictures of them, so it's not just rumor.
No lift yet for me but if no one minds two cents from an engineering standpoint.
-On this vehicle in this circumstance additional dynamic loading on the frame would be preferred rather than to the bracket on the axle housing.
-Any weld anywhere is only prequalified for the mass of material being welded. eg. more load needs more metal in addition to more weld
-The failure of the component was not the result of it being used in the manner it was designed or approved for.
Go after them though,you don't get if you don't try. But this is the reason I won't due any mods. to any drivetrain related components until my extended warranty expires. As a first model year they'll be extra vigilant to snake out of paying for anything remotely close to a design flaw at their end.
Sorry
Sorry
Here's an angle for you and others that might end up in the same boat.
You say the dealer sells Jeeps with this lift already done by the same shop.
Does the dealer offer a full manufacturers warranty if it's done through the dealership prior to delivery to customer?
If not do they offer a third party warranty?
Check with an owner of one and ask or get a buddy to go in and make like he wants to buy one.
If it's third party It's probably not worth the paper it's written on.
If It's manufacturers then you may have a reasonable argument.
