Track Bar Movement? Normal?
My wife got a case of the death wobble yesterday. Today, I had her jiggle the steering wheel while I looked at the steering linkage. Everything looks great except there was a little "play" at the top track bar mount. I have a stock track bar. Is a little play normal or should there be no play?
Thanks,
Flash
Thanks,
Flash
regardless of the torque on that bolt/nut combo - should you be able to see play if it was at 100lbs or 80lbs? just curious..... would seeing play at that point indicate wallowed holes or garbage bushing?
most likely not at 100 but maybe at 80 if your mounting holes are wollowed out and you really crank your steering wheel back and forth for a while.
it's hard to say for sure but, i would guess not or, at least not in a driveway with you just turning your wheels back and forth. of course, if you're driving and hit a pot hole or rail road track or anything really, that could be enough to jar things loose.
Flash1034. - I see you put on a lift. If you have a digital torque wrench and it said 125 ft. lbs. when you installed it, and you re-checked it periodically and it was 125 ft. lbs, and it still says 125 ft. lbs., then either it’s off and/or the hole is wallowed.
