Track Bar Movement? Normal?
I think you may see a slight amount of movement from the bushings, but it would be very minimal. If you installed the lift also can't hurt to loosen CA bolts and retorque with vehicle on it's wheels
If you do have wallowed out holes, you will need to weld washers on the bracket to make them round again. Probably best to just take the TB off & inspect the holes. If all good, reinstall and retorque to 125 ft lbs.
I agree with everyone else, make sure the holes aren't oval-ed out. If they are, no amount of tightening is gonna matter.
I had horrendous death wobble that was so bad, it would shake it right out of gear. (6 Spd) I got new 17 inch rims and new tires and my problem completely went away. It turned out it was the stock goodyear wrangler tires. My mechanic said they are a huuuge problem. I googled those particular tires and the reviews were awful
Well, the death wobble got so bad I had to have the Jeep towed to Jeep. It started 3 days ago and got progressively worse. So far, Jeep said they are replacing the track bar mounts. Isnt that a welded on piece?
Flash
Flash
Flash,
Also a good idea to file a safety complaint here..
https://www-odi.nhtsa.dot.gov/ivoq/online.cfm
Flash,
Flash
