Truth about Dana 30s
Old Oct 4, 2011 | 04:40 PM
  #31
Its_a_JK's Avatar
Sponsoring Vendor
Epic-Addictions Representative
I have 37's on a Dana 30! I have wheeled every weekend this year pretty hard. Nothing broke or bent yet. I have no doubt I will eventually but.......
Old Oct 4, 2011 | 06:07 PM
  #32
Stepsride's Avatar
Originally Posted by jeepmojo
i go down some roads that have mucky ruts in them but i go like under 5mph im tellin ya since the day i bought this its been non stop agrivation just buyin stuff and ordering problems , then of course the usual leaks and then worrying about not having right gearing for wheels and then i hear oh youl need to beef up the dana 30 !! and i call and they say 2000 for gears and its a job to do gussets and axles and youl need a pro cal and youl need superchip but they dont make one for 2011 yet youl need a cat back any clunking is a jeep thing when shifting ! youl have to get the tire carrier ! i did then its well you got extra weight youl have to try and reduce it , take out the rear seat !
its a wonder why i havent gone nuts by now its been 8 months of this llokin at everyones jeep problems and wondering if mines going to do this too ! thanks for the good reply ! made my day ! i better get off here before i read another thing like the transfer case bushings that break off and leave you stranded ! i hope i can sleep now worrying about this !!
Settle down there buddy! There are many people that beat the snot out of there rigs. It sounds like you are not going to be doing half of the crazy stuff some of these folks are doing. Just keep the maintenance up and you are good. Use the Project JK for hints and how too. Think of your jeep as LEGO. One day you like the way something works and six months later you do not. That is the fun of a Jeep, you get to build it break it down and build it again. Use some restraint on the gas peddle and you will get many years of wheeling out of your jeep.
Old Oct 4, 2011 | 06:21 PM
  #33
fadeout's Avatar
Was that internet sarcasm? I'm confused...
Old Oct 4, 2011 | 07:08 PM
  #34
Brandon1024's Avatar
Ordering my EVO sleeves and gusset package from Northridge today or tomorrow along with my MORE body lift to run my 37's
Old Oct 4, 2011 | 07:34 PM
  #35
wayoflife's Avatar
JK-Forum Founder
Originally Posted by B 1000
Will these require anything else different since they use CV instead of U joints? Any company you recommend?
no, you will not need anything different. as far as other companies go, superior, foote, alloyusa, ten factory all make good chromoly shafts.
Old Oct 4, 2011 | 07:38 PM
  #36
wayoflife's Avatar
JK-Forum Founder
Originally Posted by WXman
I've only had my JK for a few months, so obviously I've seen no problems.
I had a YJ and ran larger than stock tires on it and wheeled it fairly good...never had an issue. My buddy had a YJ and was rough as hell on it...even jumped it with all four off the ground sometimes. Not one single issue. My father drives a TJ with heavy oversized TreadWright tires and has wheeled it fairly hard. Zero issues. I'm not even going to get into the ZJs we have built and modded and wheeled.
I have NEVER once seen anything on a Dana 30 break or bend. Not a U-joint, C, housing, gear set, shaft, nothing. Not one failure.
That's just my personal experience. I think the D30 is tougher than a box of nails.
yeah, sure, tougher than a box of nails...
dont get me wrong but, a JK is no YJ, TJ or ZJ. out of the box, they weigh about 5,000 lbs and, once you build one up, they can easliy get up to 6,000+ lbs. this is a MUCH bigger and heavier vehicle and these pics are just a few that i've personally seen break and believe me, there are way more. of course, this is to say nothing about the dana 44 breaks i've personally had and have seen.
Old Oct 4, 2011 | 07:41 PM
  #37
wayoflife's Avatar
JK-Forum Founder
Originally Posted by scotty6336
Thats a close call for your uses. 4.88's would give more peace of mind I guess.
agreed. just because 5.13 is the better ratio to go with doesn't mean it the best option to go with. if you plan on doing any wheeling and or hope to install a locker in your dana 30, a really small pinion is something that will be a weak point. and, if you've ever broken a ring and pinion on the trail, i can tell you that it's no fun.
Old Oct 4, 2011 | 08:18 PM
  #38
Well I can say that my jeep is my life but your way of life is different than mine. I dont think the trails I run with be half of what you do although I wish they could be. I dont really see lockers ever being needed (at least for while im in college) once out of college there will be a whole new point of builds. At that point ill either be moving to a new jeep and or building this up with bigger axles and everything. Im just trying to decide what is best for me right now for moderate offroading and trails.
Old Oct 5, 2011 | 12:34 AM
  #39
leolito's Avatar
... Shafts are perhaps another weaker point, though IMO really no more so than a D44. You could get chromo shafts, or carry trail spares...this would be the cheapest way.
If you do all that then you got the ring and pinion as the weak point. 4.88's are really the highest (numerically) that I'd go, but thats just me. Plenty of guys run 5.13's.
Perhaps a dumb question, but from the point of view of eventual repair costs (but also ease of repair), is it better to leave the original shafts as a 'fuse' or they are too weak/complicated to replace so is better to upgrade and leave the u-joint at the wheel hub become the eventual 'fuse'? Note my lack of experience in the matter (but I am starting to inquiry to learn about it! )
Old Oct 5, 2011 | 12:55 AM
  #40
jeepmojo's Avatar
Default pics tell so much !
thats prety crazy there ! are these people dropping off rocks with them or just goin through mud and stuff ?? this forum is great you learn a lot from people here !
