upgrade computer
Old Aug 31, 2009 | 06:01 PM
04DrBlur's Avatar
I have a 2dr 6 speed with stock gears (3.21) runnin 36" Iroks and the Superchips is unbelievable. I see an extra 2-3 mpg on top of the performance it adds to the mix. I do have a CAI and exhaust though which might help my results. If I could keep my foot off the gas I would probably see better mpg results...
Old Aug 31, 2009 | 06:03 PM
JPop's Avatar
Originally Posted by GOOVERIT
JPop - DO YOU RUN A CHIP AND CAN YOU FILL THE 25HP THEY CALL FOR ?
YOU CAN TALL I'M A OLD DUDE. I HAVE NOT FOUND ANY GOOD PARTS AND WAS LOOKING REAL HARD AT THE CHIP ROUTE. I KNOW THAT WITH ALL THE PERIMETERS THAT ARE NEEDED TO RUN A PEAK POWER I'D NEED CHIP.
Well, I'm probably classified as an old dude as well.
The hp numbers, I dioon't know have a feel for how accurate they are, but the torque numbers are assuredly there. I don't often twist my JK past 3500 rpms, but it does get a fair amount of additional hammer rolling out of the hole.
All the conventional things you can do don't really take hold that well as the PCM is looking for it's known values and makes what it deems as the appropriate responses. When the stock components aren't there and the desired responses aren't found it's left scratching it's head. Certainly the downside of drive by wire.
That said, the SC Flashpaq woke my upgrades and my JK up. I wasn't chasing things any more and found power right out of the box. Same with on my Dodge Ram, where I have different than stock heads and a cam. It works great and on both vehicle I can say it was the best performance enhancement I mad while far from the most expensive.
Old Aug 31, 2009 | 06:06 PM
JPop's Avatar
Originally Posted by stlfan06
Are all you guys sayin "superchips is the way to go" running stock tires/suspension or otherwise? Auto or 6-speed? I have a 2dr, 6-speed, running stock 32s. What would I notice if I purchased this product?
I'm just trying to get some more in-depth responses. Rather than just yes/no whatever..
You can check my profile to see how my rig is laid out. Also, for some additional information there is a thread that is an easy couple hours of reading on the Superchips Flashpaq.
https://www.jk-forum.com/forums/modified-jk-tech-2/superchips-flashpaq-jk-initial-impressions-80188/
Old Aug 31, 2009 | 06:28 PM
zero_traction69's Avatar
its for a stock jeep, 6 speed i want to get more power out of it so sounds like super chip is the way to go...
Old Sep 1, 2009 | 05:42 AM
GOOVERIT's Avatar
JPop I can see what you and saying about the PCM. If I give it more fuel by way of cam and head work it will confuse it. I have missed the days of HOT ROD engine work. I will take a good look at the SUPERCHIP threads on this site. Thanks for your insight.
