Upgraded Steering
Old Nov 22, 2011 | 07:48 PM
knnphillips's Avatar
Default Upgraded Steering
Went out to Uwharrie over the weekend in my JKU Rubi on 2.5 Teraflex lift and 35x12.5x15s. The only repeated issue I was having was my steering stabilizer bracket on my tierod kept hanging on the rocks on the more extreme lines. I was wondering what I should look into to beef up or highsteer my stuff. I've heard that not much can be done running 15s also heard highsteer on a 2.5 lift would kill my uptravel (currently not running extend bumpstops) but would love to see which options are out there.
Old Nov 22, 2011 | 07:56 PM
tattedfire's Avatar
Just losen your SS bracket and rotate it up above your tie rod
Old Nov 22, 2011 | 08:00 PM
That won't affect the other end of the stabilizer? Another question is there a beefier tie rod out there such as Rock Krawler that works with 15 inch wheels?(not sure if the RK one does or not)
Old Nov 23, 2011 | 12:56 AM
nthinuf's Avatar
If you don't find a steering upgrade that will fit the 15's, there are several relo brackets available that let you rotate the stab to the top of the tie rod. $30-$35 or so. At least that will get it up out of harms way.
Old Nov 24, 2011 | 07:23 AM
Does anyone know if the Rock Krawler Heavy Duty PRO Tie Rod will fit with 15s? Appears to be there is. Which Tie Rod ends do they use with their Tie Rod?
Old Nov 24, 2011 | 12:56 PM
Originally Posted by JKred
I believe this uses the same ends as the factory drag link
Thanks looks like I'll have to order that once the cash flow allows.
