vibration/wobble...help needed
Old Oct 15, 2011 | 06:54 AM
  #21
JEP THNG's Avatar
Originally Posted by DEADGUY11
I have the same problem at around 55-65 mph.... sometimes its there sometimes its not.... smetimes its really felt throught the steering wheel other times its subtle. Ive tried diffrent toe settings, diffrent caster angles and have checked all compnents with no avail. I rack it up to the wheels and tires since when i rotate its not nearly as bad and ive just had them rebalanced again. My next route is to try these http://www.innovativebalancing.com/index.php since my buddy is using them with no problems whatsoever. Good luck
I have thought about this, but didn't know if the noise would be annoying.
Old Oct 15, 2011 | 07:07 AM
  #22
DEADGUY11's Avatar
as far as i know there is no audible noise.... especially with mud terrian tire and or and exhaust if you have one. As far as feeling a driveshaft vibration in the steering wheel in my opinion it is 2 totally diffrent feelings, the driveshaft is a very fast oscillating feeling like a vibration on a cell phone, a tire wobble vibration is more of a "slower" wobbling kind of feeling. Hope this helps
Old Oct 15, 2011 | 07:16 AM
  #23
JEP THNG's Avatar
it does help. I have had this since i lifted and put new wheels and tires on. I honestly feel like the wheels are messed up. When I had them balanced yesterday i could see the tire had a side to side movement on the machine. The guy said that they all did that and I have a hard time believing that. Shouldn't the tire be perfectly straight on the balancing machine?
Old Oct 15, 2011 | 07:34 AM
  #24
DEADGUY11's Avatar
yeah there really should be no movement in the tire from side to side. It could be a bad batch of tires or the rims themselves. Idk if anyone mentioned this "most likley" but if you have your stock wheels and tires put those on and see what happens. If it goes away then you found your problem
Old Oct 15, 2011 | 08:42 AM
  #25
JEP THNG's Avatar
Originally Posted by Double Nasty
Check your track bar bushings on you lift kit alignment and tires 9x's out of 10 its the bushings in the lift kit had the same problem and replaced everything in the front end and then i changed out the bushings in the lift kit and it was fixed
I did that. I even took it to a shop to be sure. Then torques it to 125 with red locktight.
Old Oct 15, 2011 | 08:53 AM
  #26
Bnizzle's Avatar
Originally Posted by planman
I am sure you have pulled the lug retainer clips to run aftermarket wheels right?
ugg i just put new rims and meats on my ride do i need to take off the clips? i saw them on there but havent heard anything on line about taking them off. I do not have any issues so far (fingers crossed) with wobble or anything from puting on my TF 3" on two days ago...should i pull those clips?
Old Oct 15, 2011 | 09:33 AM
  #27
JEP THNG's Avatar
I have been told by multiple people to take them off. I heard they cause wobble/shake/vibration.
Old Oct 15, 2011 | 11:00 AM
  #28
Bnizzle's Avatar
strange that they would be fine for stock rims and not for aftermarket...is it the size of the tire that makes it wobble with them? why even have them in the first place.....anyone got some tech answer for this?
Old Oct 15, 2011 | 12:48 PM
  #29
Bnizzle's Avatar
ouch, gona get them off then thanks!
Old Oct 15, 2011 | 01:26 PM
  #30
Blackbelt Chick's Avatar
The clips are on there to facilitate the assembly line manufacturing process.
The stock wheels are built with openings around the lugs to fit over the clips.
They absolutely must be removed to run wheel spacers or anything other than stock wheels.
They prevent aftermarket wheels from sitting flush on the disc. Because they are not on every lug, they will eventually damage your aftermarket wheels if not removed. The wobbles from failing to remove them are the least of your worries. Ruined wheels are a bigger problem.
Does that go for the 2012 model too?? I ordered wheels today and they will be in next week. Does the tire shop know to do this??
