vibration/wobble...help needed
Old Oct 15, 2011 | 05:44 PM
  #31
DEADGUY11's Avatar
regardless of what year you have you have to take them off. like posted above, the stock wheels are made for these clips aftermarket r not and also when you change your rotors down the line you will have to remove them anyways so do yourself a favor and toss em!
Old Oct 27, 2011 | 05:11 AM
  #32
Pepperdine's Avatar
I am having the same problem as described above since I got my lift, tires and wheels.. After new Ball Joints, Steering Stabalizer and 4-5 ballences I still get rapid shakes in the wheel between 48-53mph. I wish I would have left everything stock because I am annoyed to even drive it. I thought that maybe ballencing a 15x8 wheel might be the problem but I read this is happening with larger diamiter rims as well.
I wonder if because my wheels are not hubcentric if I need hub rings??? I read that some wheels cause vibrations if you don"t have hubrings...
I may end up switching back to the stock wheels and puting 33"s on those.
Old Oct 27, 2011 | 07:09 AM
  #33
Jeep(NV)'s Avatar
Hub rings will help ensure that your non hub centric rims are perfectly centered. I am getting this same vibration with my MB72 15x8 wheels with a 78.1 hub bore and the jeeps hubs is 71.5. So if you don't torque your wheels in the air your rims could be off center a little bit due to the difference in the rims hub bore and the jeep hub size. If I torque my wheels on the ground the vibration is terrible, so now I make sure to torque them in the air.
Old Jul 12, 2013 | 02:26 PM
  #34
njfirefighter92's Avatar
Make sure whoever is balancing your tires uses the lug-centric attachment for the balance. Otherwise it will not be accurate
Old Jul 13, 2013 | 12:30 AM
  #35
kjeeper10's Avatar
Vet Army
I bring this up every time I find a new shop.
They look at me like I have 3 heads :(
