wandering and clunk in front steering system
Old Mar 23, 2013 | 09:54 AM
Kojack's Avatar
Default wandering and clunk in front steering system
I have noticed my rig wandering more lately. I am also getting a slight knock which is not the jk clunk, but something else. My mechanic said the ball joints are fine but I'm not so sure. 85k on them. I don't trust them.
Old Mar 23, 2013 | 09:58 AM
hypeiv's Avatar
long shot but the tie rod end of my JK steering stabilizer worked it self loose causing it slide around when I was making slow tight turns causing a clunk sound. You might want to check that.
Old Mar 23, 2013 | 11:30 AM
mpkelley20's Avatar
Check your draglink ends as well. One of those come loose and it can cause your symptoms.
Old Mar 23, 2013 | 01:22 PM
miethead's Avatar
Mine has started doing the same. Checked everything underneath and noticed the steering is leaking all down the pitman arm
Old Mar 23, 2013 | 02:03 PM
Freewill's Avatar
Ball joints, tie rod ends, wheel bearings, steering box, relay rod (drag link) joints - plenty of possibilities.
But, the trackbar bolts are as likely as anything and easy to check for looseness.
Old Mar 23, 2013 | 02:55 PM
JK KIWI's Avatar
I would check your sector shaft out of the steering box, as that makes a clunk sound when loose!
Old Mar 23, 2013 | 03:33 PM
Kojack's Avatar
That the shaft between steering wheel and box? I know about that one.
Old Jun 2, 2013 | 07:51 PM
jjmmagoo's Avatar
I have a clunk sound when i go over any type of hard bump. It sounds like its in the front right side of the JK. I had it at the dealership last year. They couldnt find anything wrong with it!! They had it for like a week!!!! Still nothing! I still hear it. For a person that doesnt have much expierence with being under the hood or under a car what should I look for? Is this something I can fix on my own??? Its getting frustrating! I just keep thinking that there has to be something wrong!!! Any help would be greatly appreciated! Thanks!!!
Old Jun 2, 2013 | 07:55 PM
familytime's Avatar
JK Forum Regional Rep
Try and do a search
Old Jun 3, 2013 | 06:06 AM
jjmmagoo's Avatar
Thanks for the advise. I have been doing searches and with so many possibilities all I was trying to determine is, is this something that I can fix on my own?
