Weird Vibration
Old May 8, 2016 | 04:02 PM
  #21
Wandap11's Avatar
Default Weird Vibration
Drag link is not flipped
Old May 8, 2016 | 04:03 PM
  #22
PsychoCupcake's Avatar
Originally Posted by Wandap11
Sorry! Control arms are stockdde44
4" of lift and stock control arms. Sounds like there might be more to your vibration that the tires. Your caster and pinion angle are way out of whack with that setup. You either need adjustable control arms or geometry correction brackets. And as others will likely chime in, with 4" of lift you should consider hi steer. Does your steering feel flighty?
Old May 8, 2016 | 04:48 PM
  #23
DunnyBunny's Avatar
JK-Forum Ambassador
Nailed it!!!
Old May 8, 2016 | 04:57 PM
  #24
Wandap11's Avatar
Lift did come with Cam bolts to go with lower control
Old May 8, 2016 | 04:58 PM
  #25
Wandap11's Avatar
Steering is fine
Old May 8, 2016 | 05:02 PM
  #26
DunnyBunny's Avatar
JK-Forum Ambassador
Ugh cam bolts.
Hopefully tire rotation and balancing fixes your issue.
Old May 8, 2016 | 05:16 PM
  #27
Wandap11's Avatar
Are Cam Bolts an issue?
Old May 8, 2016 | 07:01 PM
  #28
DunnyBunny's Avatar
JK-Forum Ambassador
They aren't the best but you got them in so little late now.
